17249 Discussions
Internal error in Quartus 11??
I have a project with import partition,and it can pass analysis&synthesis.
then a internal error happen when fitter, as following.
Internal Error: Sub-system: CSYN, File: /quartus/db/csyn/csyn_expert.cpp, Line: 2069
pre_icp_ok
Stack Trace:
0x3fdb6: CSYN_EXPERT::late_fsyn_flow + 0x1b6 (DB_CSYN)
0x13ce37: CSYN_TIMING::dump_timing_mode + 0x57 (DB_CSYN)
0x137881: CSYN_TIMING::on_flow_start + 0x151 (DB_CSYN)
0x158ad: _Dinkum_std::vector<bool,MEM_STL_ALLOCATOR<bool> >::~vector<bool,MEM_STL_ALLOCATOR<bool> > + 0x3d (DDB_DYGR)
0xfe0d: DYGR_DIE_INFO_BODY::is_data_loaded + 0x2dd (DDB_DYGR)
End-trace
Quartus II Version 11.0 Build 208 07/03/2011 SJ Full Version
Service Pack Installed: 1
the OS of PC is windows XP.
Cut "db and incremental db" folders and paste it anywhere except your project directory (just for backup if something wrong) and again compile without those folders.
It is real a good idea!,, and work well,
