I have a project with import partition,and it can pass analysis&synthesis.
then a internal error happen when fitter, as following. Internal Error: Sub-system: CSYN, File: /quartus/db/csyn/csyn_expert.cpp, Line: 2069 pre_icp_ok Stack Trace: 0x3fdb6: CSYN_EXPERT::late_fsyn_flow + 0x1b6 (DB_CSYN) 0x13ce37: CSYN_TIMING::dump_timing_mode + 0x57 (DB_CSYN) 0x137881: CSYN_TIMING::on_flow_start + 0x151 (DB_CSYN) 0x158ad: _Dinkum_std::vector<bool,MEM_STL_ALLOCATOR<bool> >::~vector<bool,MEM_STL_ALLOCATOR<bool> > + 0x3d (DDB_DYGR) 0xfe0d: DYGR_DIE_INFO_BODY::is_data_loaded + 0x2dd (DDB_DYGR) End-trace Quartus II Version 11.0 Build 208 07/03/2011 SJ Full Version Service Pack Installed: 1 the OS of PC is windows XP.Link Copied
Cut "db and incremental db" folders and paste it anywhere except your project directory (just for backup if something wrong) and again compile without those folders.
It is real a good idea!,, and work well,
