17254 Discussions
Internal error with new project wizard
Hi All,
I'm getting an internal error with Quartus 11.0sp1 when trying to run the new projects wizard. Also I can't load existing project file, Quartus bombs out. Any ideas?
Mark.
Edit: This error only happens with the 64bit version, the 32bit version seems OK.
Edit again: This happened the first time I ran Quartus 64bit. I then ran Quartus 32bit and all was fine. I ran Quartus 64bit again and this seemed fine too.
Details of error:
p, li { white-space: pre-wrap; } *** Fatal Error: Access Violation at 0X00000000671008AB
Module: quartus.exe
Stack Trace:
0x1008aa: QMetaObject::cast + 0x1a (QtCore4)
0x3c69c1: QMdiArea::eventFilter + 0x71 (QtGui4)
0xfc562: QCoreApplicationPrivate::sendThroughApplicationEventFilters + 0x92 (QtCore4)
0x1ffbd: QApplicationPrivate::notify_helper + 0x1d (QtGui4)
0x235c4: QApplication::notify + 0x1c24 (QtGui4)
0xfc4b0: QCoreApplication::notifyInternal + 0x70 (QtCore4)
0x1f89f: QApplicationPrivate::enterModal + 0x33f (QtGui4)
0x703a6: QWidgetPrivate::show_helper + 0x226 (QtGui4)
0x70acc: QWidget::setVisible + 0x30c (QtGui4)
0x44622d: QDialog::setVisible + 0xcd (QtGui4)
0x44499d: QDialog::exec + 0x9d (QtGui4)
0x4b8cd: AFCQ_MSG_DISPLAY::prompt_display + 0x3bd (GCL_AFCQ)
0x2f4e4: MSG_YN::prompt + 0x44 (CCL_MSG)
0x5997a: QUI_PRJ_UI_MGR::new_prj_wiz_action + 0xba (SYS_QUI)
0x15029: QUI_FRAME_WND::on_new_prj_wiz_action + 0x59 (SYS_QUI)
0xdba1: QUI_FRAME_WND::qt_metacall + 0x721 (SYS_QUI)
0x9661: QGQ_MAIN_WINDOW::qt_metacall + 0x21 (SYS_QGQ)
0x1111ec: QMetaObject::activate + 0x35c (QtCore4)
0xdfdf: QAction::activate + 0xdf (QtGui4)
0x3d3012: QMenu::findIdForAction + 0x342 (QtGui4)
0x3d9aed: QMenu::internalDelayedPopup + 0xb4d (QtGui4)
0x6cd5a: QWidget::event + 0xca (QtGui4)
0x3d9e97: QMenu::event + 0x2a7 (QtGui4)
0x200a1: QApplicationPrivate::notify_helper + 0x101 (QtGui4)
0x22182: QApplication::notify + 0x7e2 (QtGui4)
0x21602: QApplicationPrivate::sendMouseEvent + 0x1e2 (QtGui4)
0x83e26: QApplication::winFocus + 0xa36 (QtGui4)
0x86f25: QApplication::restoreOverrideCursor + 0xbe5 (QtGui4)
0x19bd0: TranslateMessageEx + 0x2a0 (USER32)
0x198d9: TranslateMessage + 0x1e9 (USER32)
0x123eb4: QEventDispatcherWin32::processEvents + 0x544 (QtCore4)
0x86294: QApplicationPrivate::translateTouchEvent + 0x824 (QtGui4)
0xfbab0: QEventLoop::exec + 0x150 (QtCore4)
0xffedf: QCoreApplication::exec + 0xdf (QtCore4)
0x1928: msg_exe_fini + 0xf8 (CCL_MSG)
0x18cc: msg_exe_fini + 0x9c (CCL_MSG)
0x57c4: MEM_UTILS_CHUNK_ALLOC::chunk_malloc + 0x194 (ccl_mem)
0x2f084: msg_exe_main + 0x74 (CCL_MSG)
0x1652c: BaseThreadInitThunk + 0xc (kernel32)
0x2c520: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Quartus II 64-Bit Version 11.0 Build 157 04/27/2011 SJ Full Version
