17261 Discussions
Is there a Synthesizable syntax with writing file in verilog??
euem789
Hi guys,
Now I'm Using
Software : Quartus 18.1
Board : DE1 - Soc
I'm facing problem with FILE IO in verilog . (
what I want to do is making an output file with synthesizable syntax (targeting the implementation of FPGA board Not for simulation)
here's the code I wrote.
module readmem(clk);
	input clk;
	reg [7:0] rmem [0:2];
	reg [7:0] wmem [0:2];
	initial begin
		$readmemb("C:\\test_num.bin",mem);
		$writememb("C:\\test_num_reslut.bin",wmem);
		wmem[0]=(rmem[0]<<1);
		wmem[1]=(rmem[1]<<1);
		wmem[2]=(rmem[2]<<1);
	end
endmodule
After compile what I expected  was generated  output file 'test_num_result.bin'  but nothing happend.
I heard that $readmem syntax is able to synthesize( also used for memory initialization),  and there was no problem with compilation.
and no error with $writemem syntax too.
Could someone tell me am I doing right??
I'll be really appreciated if someone tell me what's wrong....
and furthermore,
- Is it possible to perform only with verilog in quartus??
  or do I have to use a soft processor (NIOS) ??
( What I'm trying to do for my project is reading a image file with applying sobel-mask and then, making an output file through my FPGA board)
thanks for reading
KhaiChein_Y_Intel
According to https://www.intel.com/content/www/us/en/programmable/quartushelp/current/index.htm#hdl/vlog/vlog_list_support_d1625e1153.htm, only $readmemb/$readmemh are supported.
KhaiY
KhaiChein_Y_Intel
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
KhaiY
