17257 ディスカッション
Is there a maximum number of interfaces allowed in the Component Editor?
DDARN2
ビギナー
1,493件の閲覧回数
When I am adding interfaces and signals to a component in the component editor, I can save the component and then reopen it and many of the interfaces I defined are gone. This also happens when there is an error in one interface. Is there some order I need to follow to correct errors without having to redefine existing interfaces?
0 件の賞賛
10 返答(返信)
KhaiChein_Y_Intel
従業員
1,283件の閲覧回数
May I know which editor you are referring to, the Intel IP component editor or custom IP component editor?
DDARN2
ビギナー
1,283件の閲覧回数
I am referring to the Intel Component Editor within the Platform Designer. I am using it to create a custom component.
sstrell
名誉コントリビューター III
1,283件の閲覧回数
Are you finishing the Component Editor and getting the message that it will create a _hw.tcl file? That's where the interfaces and signaling would be saved. There's no limit on signals/interfaces that I know of.
#iwork4intel
DDARN2
ビギナー
1,283件の閲覧回数
Yes, I finish the component editor and chose to save. At that point, it writes to the _hw.tcl file. The first time I saved my component, I did not include all the interfaces. To add additional interfaces, I edited the component and continued adding. The next time I saved, multiple, previously added components were removed from the .hw.tcl file. I've tried tackling this in different ways, like adding them one at a time and saving in between (very time consuming); however, I always get to a point where the save action removes interfaces that were previously added. At this point, I have opted to edit the tcl file directly and stop using the Component Editor, especially after finding multiple postings in the Community regarding the flakiness of that tool.
sstrell
名誉コントリビューター III
1,283件の閲覧回数
When you say you "edited the component and continued adding", do you mean that you right-clicked the custom component in the IP Catalog and selected Edit? That's the way to continue updating an existing custom component using the graphical tool. From your description, it sounds like when you are "editing" a component, you are actually starting over and creating a new _hw.tcl file that is overwriting the old one.
Recent versions of Platform Designer create backup _hw.tcl files (I think they are named _hw.tcl~). Have you checked these backups and compared them to the current _hw.tcl?
#iwork4intel
DDARN2
ビギナー
1,283件の閲覧回数
Hello, I was only using the "Edit" option from the right-click. The tool would (seemingly) randomly remove interfaces that I had already saved to the *_hw.tcl file from the previous exit.
Eric
sstrell
名誉コントリビューター III
1,283件の閲覧回数
Have you looked at the backup file(s) with a ~ to see if the interfaces that were removed are present there?
#iwork4intel
DDARN2
ビギナー
1,283件の閲覧回数
Yes, they were and are not present.
KhaiChein_Y_Intel
従業員
1,283件の閲覧回数
Can you provide a sample test case and steps to reproduce the error?
KhaiChein_Y_Intel
従業員
1,283件の閲覧回数
Do you have any updates?
返信
