17255 Discussions
Issue with Quartus Prime PRO for Stratix 10 when using a string type in a VHDL project.
JDlug
When using "Quartus Prime Pro 20.1" software with "Stratix 10" chip, I have a problem with VHDL string type in my projects. At the same time, I don't have this problem when using "Quartus Prime Standard Edition 19.1" with "MAX 10" FPGA. For example, the problem occurs when I compile the following simple VHDL code:
 LIBRARY ieee;
 USE ieee.std_logic_1164.all;
 ENTITY e1 IS
  PORT
   s_out: OUT string(1 to 2)
 END e1;
 ARCHITECTURE arch1 OF e1 IS
 BEGIN
  s_out <= "ab";
 END arch1;
The compilation process stop suddenly and the error popup window appears with the message: "Sorry! The Quartus Prime software quit unexpectedly". Here is a preview of the report:
Problem Details
Error:
Internal Error: Sub-system: QIS, File: /quartus/synth/qis/qis_name_processor.cpp, Line: 779
\s_out[1].'|' is not a valid node name
Stack Trace:
 Quartus   0xa4d85: QIS_NAME_PROCESSOR_IMPL::create_names + 0x885 (synth_qis)
 Quartus   0x3834b: QIS_RTL_STAGE::IMPL::create_instance_name_for_node + 0x8b (synth_qis)
 Quartus   0x38b0d: QIS_RTL_STAGE::IMPL::create_names_for_all_nodes_post_extraction + 0x2dd (synth_qis)
 Quartus   0x3e9ab: QIS_RTL_STAGE::IMPL::post_process_elaborated_entity + 0xc6b (synth_qis)
 Quartus   0x3a631: QIS_RTL_STAGE::IMPL::elaborate + 0x16d1 (synth_qis)
 Quartus   0x18e2e: qis_elaborate + 0x26e (synth_qis)
 Quartus   0x16442: TclNRRunCallbacks + 0x62 (tcl86)
 Quartus   0x17c4d: TclEvalEx + 0x9ed (tcl86)
 Quartus   0xa6a8b: Tcl_FSEvalFileEx + 0x22b (tcl86)
 Quartus   0xa5136: Tcl_EvalFile + 0x36 (tcl86)
 Quartus   0x156f6: qexe_evaluate_tcl_script + 0x4e6 (comp_qexe)
 Quartus   0x145e3: qexe_do_tcl + 0x4b3 (comp_qexe)
 Quartus   0x1acae: qexe_run_tcl_option + 0x5ee (comp_qexe)
 Quartus   0x18c31: QCU::DETAIL::intialise_qhd_and_run_qexe + 0xa1 (comp_qcu)
 Quartus   0x2b0e2: qcu_run_tcl_option + 0x2f2 (comp_qcu)
 Quartus   0x13cc: qsyn2_tcl_process_default_flow_option + 0x1dc (quartus_syn)
 Quartus   0x1a5b0: qexe_run + 0x460 (comp_qexe)
 Quartus   0x1b6ea: qexe_standard_main + 0x26a (comp_qexe)
 Quartus   0x3039: qsyn2_main + 0x129 (quartus_syn)
 Quartus   0x158d8: msg_main_thread + 0x18 (CCL_MSG)
 Quartus   0x16f81: msg_thread_wrapper + 0x71 (CCL_MSG)
 Quartus   0x21040: mem_thread_wrapper + 0x70 (ccl_mem)
 Quartus   0x14e5d: msg_exe_main + 0x20d (CCL_MSG)
 Quartus   0x4924: __scrt_common_main_seh + 0x11c (quartus_syn)
 Quartus   0x17bd3: BaseThreadInitThunk + 0x13 (KERNEL32)
 Quartus   0x6ce70: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Executable: quartus_syn
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 20.1.0
Build: 177
Edition: Pro Edition
How can I solve this problem?
Thank you in advance for any help.
(jd)
JDlug
Hi KhaiY,
I'm sorry I didn't answer. I usually received emails with every new forum post about my topic. I haven't received any email right now, so I didn't know you sent new messages.
I really appreciate that Intel will fix the problem. Do you have any information when this could happen?
Thank you,
(jd)
KhaiChein_Y_Intel
Hi JD,
The team did not share the exact version but this is in the preliminary plan of the future release.
KhaiY
JDlug
KhaiY,
Thank you very much for the information.
(jd)
KhaiChein_Y_Intel
Hi JD,
No problem.
KhaiY
