17247 Discussions
Issues Building Intel Nios V/g core
Samuel6
I have just installed Quartus Pro 24.2, but I am having issues building designs containing Nios V/g.
I downloaded the Arria 10 Nios V/g Design Example, but when I try to build it I get an Error during the Analysis and Synthesis step saying this:
Verilog HDL or VHDL error: cannot open Verilog file 'ip/sys/cpu/intel_niosv_g_unit_220/synth/niosv_opcode_def.sv'
This error is repeated for most of the other files within that folder, specifically it's all the binary/encrypted files where I can't view the source code, but this error doesn't occur for the files which can be viewed in a text editor.
I also downloaded the  Arria 10 Nios V/m Design Example, and that builds without issues, so my problem seems to just relate to the Nios V/g. Does anyone know what could be causing this and what can be done to fix it?
Many Thanks,
Samuel
Samuel6
I thought it might be a license issue but I was confused as I have a valid license which I've used to build Nios V/g in Quartus Standard, however I've realised the Flexlm License Daemon we were using was out of date, and updating it to a newer version has resolved my issue.
I'm surprised Quartus doesn't give a warning about this, or even that Quartus opens if I was using an unsupported version, but at least I've fixed it now.
Thank you for your reply,
Samuel
sstrell
It sounds like a licensing issue.  You can get a free license through the SSLC, linked from the Nios V page with directions of what you need to get: https://www.intel.com/content/www/us/en/products/details/fpga/intellectual-property/processors-peripherals/niosv.html
Samuel6
Samuel
JingyangTeh_Altera
Hi
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
JIngyang, Teh
