17267 Discussions
Iteration limit reached
NEwton826
I have wrote a code for UART using FSM.I am getting the above error when I am using VWF .I known the part of the code that is causing the problem. TX_DATA_BITS. But can't understand why.
Please help me regarding it .
Thank you
sstrell
Can you show the full error message and a screenshot of your waveform?  My guess is that add_count is going to 8 in the combinatorial logic before it is reset, which would exceed the number of bits in S.
NEwton826
@sstrell
Here is the error pic.
I don't think going to 8 is possible in my code because at 7 I reset it .
RichardTanSY_Altera
Have you try to simulate it using the Modelsim Intel FPGA Edition and check if the issue persist?
