Simulation tutorial
pese
I get the error message below when running the waveform editor - not very informative...?
# vsim -novopt -c -t 1ps -L fiftyfivenm_ver -L altera_ver -L altera_mf_ver -L 220model_ver -L sgate_ver -L altera_lnsim_ver work.light_vlg_vec_tst
# Start time: 17:13:46 on Nov 23,2020
# ** Error (suppressible): (vsim-12110) The -novopt option has no effect on this product. -novopt option is now deprecated and will be removed in future releases.
# Error loading design
# End time: 17:13:46 on Nov 23,2020, Elapsed time: 0:00:00
# Errors: 1, Warnings: 0
Error.
RichardTanSY_Altera
In the simulation waveform editor > Simulation > Simulation Setting,
Change the modelsim script by removing the '-novopt', example:
vsim -c -t 1ps -L fiftyfivenm_ver -L altera_ver -L altera_mf_ver -L 220model_ver -L sgate_ver -L altera_lnsim_ver work.light_vlg_vec_tst
Then run the simulation again and see if it works.
RichardTanSY_Altera
Do you able to solve the issue based on the my latest reply?
RichardTanSY_Altera
We do not receive any response from you to the previous question/reply/answer that I have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
