17252 Discussions
Latch-initialization in quartus prime
Lera_Dyakova
Program was written using a latch. The latch has an initial initialization, for example = "0000001", but Quartus incorrectly initialized the latch, ="1111111" ,this was understood with the SignalTap. Why is that?
Alberto_R_Intel
Lera_Dyakova, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance on this matter, I just moved your thread to the proper department, they will further assist you with this topic as soon as possible.
Albert R.
sstrell
Can you show some code?
Also, it's recommended to use actual registers instead of building latches out of logic gates.
Lera_Dyakova
This is interesting , because the simulation shows the correct result. This is the code:
library ieee;
use ieee.std_logic_1164.all;
use IEEE.std_logic_unsigned.all;
entity running_LEDs is
    port (
        clk : in std_logic;
        led : out std_logic_vector(7 downto 0)
end running_LEDs;
architecture rtl of running_LEDs is
    signal count : std_logic_vector(25 downto 0) := (others => '0');
    signal temp : std_logic_vector(7 downto 0) := (0 => '1', others => '0');
    signal rst : std_logic := '0';
begin
    process (clk)
    begin
        if (rst = '1') then
            count <= (others => '0');
        elsif (rising_edge(clk)) then
            count <= count + 1;
        end if;
    end process;
    process (count)
    begin
        if count = 50000000 then
            rst <= '1';
            temp(7 downto 0) <= temp (6 downto 0) & temp(7);
        else
            rst <= '0';
        end if;
    end process;
    led <= temp;
end rtl;
SyafieqS
Iera,
Are you able to work on this?
