16939 Discussions
MAX10 GPIO Lite DDR Output cant be simulated in questa
RRoze1
​using questa 2019.1
after running
vopt -reportprogress 300 tb_top "+acc=npr3" -o mydesign_opt -L fiftyfivenm_ver -L altera_mf_ver -L altera_ver -L lpm_ver -L altera_lnsim_ver
I got error
# ** Error: C:/tools/intelFPGA/17.0/quartus/eda/sim_lib/mentor/fiftyfivenm_atoms_ncrypt.v(38): in protected region
this is only for using ddio_out for MAX10 GPIO .
the ddio_in is simulated OK .
I compiled all the lib needed.
help will be welcome
Rami
Rahul_S_Intel1
Hi ,
Can you please check all the libraries got correctly.
AKuma235
MAX10 GPIO Lite DDR Output cant be simulated in modelsim 10.1d. It is showing same problem that is showed aboved.
Please give solution for it.
