17252 ディスカッション
Maximum Input Clock for FIFO
m_kumar
新規コントリビューター I
1,473件の閲覧回数
Hi
Iam using max10  fpga , having dought regarding to fifo memory block, what is the maximum input clock can be given to fifo ip.
In my project iam using fifo dual clock mode.
write clock = 240 Mhz,
read clock = 60 Mhz,
I studied device data sheet not find any information for the dought.
Thanks in Advance.
0 件の賞賛
4 返答(返信)
Ash_R_Intel
従業員
1,458件の閲覧回数
HI Manoj,
The FIFO IP uses the M9K memory component as basic block along with some logic elements. The achievable frequency is determined by overall design in the FPGA.
The datasheet provide details of M9K block used in FIFO mode for a fixed configuration. This can be considered as the basis for your estimation.
However, the actual frequency achieved can only be found out from the final Timing Analyzer report.
Ashlesha
m_kumar
新規コントリビューター I
1,451件の閲覧回数
Hi Ashlesha,
I found this details in datasheet here they mentioned that we can give input clock upto 300 MHz.
Ash_R_Intel
従業員
1,433件の閲覧回数
Hope you have got answer to what you are looking for. Is it ok to close this case?
Regards.
m_kumar
新規コントリビューター I
1,430件の閲覧回数
Hi ,
I have changed my design and reduced input clock to 80Mhz, now i am moving with the project. Anyway thanks for the information.
Manoj
返信
