17258 Discussions
MegaWizard not possible on 14.0 ??
I am using Quartus 14.0 subscription edition on Ubuntu.
I can not find the MegaWizard plug-in manager anywhere.
Has anyone had this problem? or have any suggestions please. Thanks
Paul
The MegaWizard is no more.
http://www.altera.com/literature/ug/ug_intro_to_megafunctions.pdf
(If you have stuff that was a MegaFunction and doesn't show up in the IP tab of the project navigator, you can do File -> Open, and when it opens you will see the MegaWizard.)
--- Quote Start ---
--- Quote End ---
In which case, is there a revised 'my first fpga' tutorial that doesn't require this megawizard to configure the pll and the output mux?
Rysc,
HI, were you able to configure the IP Catalog? I modified the Tools>Options>Ip Catalog> IP Catalog Search Locations to point to the Altera\14.0\ip\altera but I'm still not able to get it to work.
joe
Rysc,
HI, got it to work. The window popped up on the right of my screen and I didn't notice it until now.
joe
When I try to add in an "altpll" the MegaWizard did not finish loading. Any ideas?
