17257 Discussions
ModelSim Exit code 211 with CycloneV Fractional PLL
Fabrizio_Salerno
I'm trying to simulate on ModelSim Intel-FPGA Started Edition 10.5b a design that was compiled on Quartus Prime 18.1 on the CycloneV. The design compiles correctly, and the EDA netlist Writer functions correctly.
On modelsim I run the project.do file automatically generated by the netlist writer with the command:
do name_project_vhdl.do
Next, when I try to simulate it with the command:
vsim entity_name
ModelSim crashes with exit code 211 (segmentation fault).
This seems to happen only when the testbench generated name_project.vho has a cyclonev_fractional_pll. Without it, the project simulates correctly.
Is there a way to include cyclonev_fractional_pll without this segmentation fault? Or am I doing something wrong? Thank you.
P.S. I already tried to include the verilog version of the CycloneV library by using
vlog .../eda/sim_lib/cyclonev_atoms.v -work cyclonev_ver
and then running the command
vsim entity_name -L work -L cyclonev_ver
This gives me the same fault
RichardTanSY_Altera
Could you try to run the simulation using the Nativelink simulation flow?
Additionally, could you try using Questa Intel FPGA edition (starter/non starter) as Modelsim has been replaced by it.
If the issue still persists, could you share the project and testbench so I could try to duplicate the issue and find a solution.
Richard Tan
Fabrizio_Salerno
Hi Richard,
Thanks for the reply.
I have attempted to run the same project on Questa Intel FPGA started edition 2023.3  for the Quartus 2023.1 without success (I get error message
"Error $MODEL_TECH/../intel/vhdl/src/cyclonev/mentor/cyclonev_atoms_ncrypt.v(38): in protected region" which means the command vsim name does not work.
I think I tried the simulation flow you've asked without any success.
I'll attach a very simple project which seems to give me these issues (it's a simple PLL with 3 output clocks). The problematic file is in Simple_PLL/simulation/modelsim/e_Simple_PLL.vho, in particular the entity mapped in line 261 is the one that makes Modelsim crash.
RichardTanSY_Altera
Are you trying to run RTL simulation or gate-level simulation?
I do not see a testbench in the zip file provided.
We do not usually use gate-level simulation. We recommend that you verify your design using RTL simulation for functionality check and use the Timing analyzer for timing.
Richard Tan
Fabrizio_Salerno
Hi Richard,
I am trying to do Gate level simulations.
I was unaware that another testbench had to be made, so I made one which simply instantiates the PLL and tries to make a clock. RTL simulation seems to work fine, gate-level simulation gives me the famous crash with error code 211.
Is there any possibility of doing gate-level simulation?
I've attached the project folder with the testbench included in simulation/modelsim/tb.vhd. The commands I run on Modelsim are in order:
  • do e_Simple_PLL_run_msim_gate_vhdl.do
  • vcom tb.vhd
  • vsim e_tb.
This gives me the error code 211. If instead i use  e_Simple_PLL_run_msim_rtl_vhdl.do, the simulation works.
RichardTanSY_Altera
I am able to run gate-level functional simulation using Questa Intel FPGA with 22.1std version.
Could you try to install Quartus 22.1std and Questa Intel FPGA (or the latest 23.1std version), and run it.
Richard Tan
Fabrizio_Salerno
Hi Richard, thanks again for the reply.
I'm still having issues. I just tried to compile the project in both versions of quartus you've listed 22.1 and 23.1.
In the attachment there is the project made entirely in quartus 23.1 (therefore the IP was not upgraded, but it was redone). I've also tried changing between QuestaIntel Starter and Non-Starter Edition.
In all cases, I am still getting the same issue in the vsim command:
Error $MODEL_TECH/../intel/vhdl/src/cyclonev/mentor/cyclonev_atoms_ncrypt.v(38): in protected region.
If your version is working, could it be a problem with a license? For now I downloaded one from the intel licensing page, as my company has not yet upgraded to the latest version.
Here I've attached the latest project, and you can see that in Simple_PLL\simulation\questa\msim_transcript I am getting this error.
RichardTanSY_Altera
Do you run the full compilation(Processing > Start Compilation), which will run the gate-level simulation once the compile finish run?
https://www.intel.com/content/www/us/en/docs/programmable/683080/23-1/running-gate-level-simulation-nativelink.html
Richard Tan
Fabrizio_Salerno
Hi Richard,
I think I was following the wrong guide. This one seemed to work, and I can correctly simulate on version 22.1. Thank you!
RichardTanSY_Altera
 I'm pleased to know that your question has been addressed.
Now, I will transitioning this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
The community users will be able to help you on your follow-up questions.
Thank you and have a great day!
Richard Tan
