17267 Discussions
Modelsim Altera Starter & .tb
Hi ,
I use modelsim Altera starter 10.1b unlicensed and i can't use testbench file and simulate. My simulation is good when i use "simulate without optimization" and not with "simulate" .
I need license to use testbench file and "simulate"??
Polyced
PS:I apologize for my poor English
For ModelSim-Altera Starter-Edition, you wont need a license to simulate (it's free of charge). Have you tried simulating it using Nativelink rather than doing it manually?
yes when i run RTL simulation , i have this info in quartus :
Info (22036): Successfully launched NativeLink simulation (quartus_sh -t "c:/altera/12.1/quartus/common/tcl/internal/nativelink/qnativesim.tcl" --rtl_sim "test_pll" "test_pll_top")
Info (22036): For messages from NativeLink execution see the NativeLink log file D:/Projets electronique Quartus/Test_pll/test_pll_nativelink_simulation.rpt
Info (22036): Successfully launched NativeLink simulation (quartus_sh -t "c:/altera/12.1/quartus/common/tcl/internal/nativelink/qnativesim.tcl" -gate_netlist "test_pll_top.vho" -gate_timing_file "test_pll_top_vhd.sdo" "test_pll" "test_pll_top")
I think i use NativeLink.
I want create a testbench file to no always create my input signal.
In my first , i create manually my input siganl and export waveform in vhdl testbench.
In assignments/settings .../ simulation /compile testbench
But i run rtl simulation error loading?
From the message, it says "Successfully launched NativeLink simulation". Did ModelSim window come out? Have you set the location of ModelSim in your EDA tools options (Tools-->Options --> EDA Tool Options). Could you describe more about the problem you're facing now?
Yes modelsim window come out , and location of modelsim.
Now i want to simulate altpll with RTL and gate level. When i simulate with gate level (or rtl) my result is bad (see attached room). I modifie parameters and always same result.
And i don't want always create my input signal.
I want create a testbench file to create input file once. (see attached room)
i assign test bench file in "assignments/settings .../ simulation /compile testbench " (see attached room) And i run gate level : message : error loading design (see attached room)
I hope you understand my probleme and you can help me.
