- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
When simulating a ROM component within the testbench file (for generating a data packet) I get the Modelsim warning
# ** Warning: (vsim-3473) Component instance "inst_altera_testbench_packet_rom : altera_testbench_packet_rom" is not bound.
The ROM is a 128 x 8 with a .hex file.
The instantiation is all correct.
Any idea what is wrong?
Does Modelsim simulate ROM with Hex files?
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I tried a .mif file but same issue.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
More info:
I fixed the "is not bound" fault by ensuring Modelsim compiled the ROM first by using a script.
The next issue was 'unresolved defparam'
So I added 'altera_mf_ver' library to the vsim script as community solution suggested.
That fixed that one.
But I am left with below - same for whether I use a hex or a mif file.
# ** Warning: (vsim-3534) [FOFIR] - Failed to open file "./ip/altera_testbench_packet_rom/altera_testbench_packet.mif" for reading.
# No such file or directory. (errno = ENOENT) : /build/swbuild/SJ/nightly/18.1std/625/l64/work/modelsim/eda/sim_lib/altera_mf.v(263)
# Time: 0 ps Iteration: 0 Instance: /testbench/inst_altera_testbench_packet_rom/altsyncram_component/m_default/altsyncram_inst
# ERROR: cannot read ./ip/altera_testbench_packet_rom/altera_testbench_packet.mif.
# ** Warning: (vsim-7) Failed to open readmem file "./ip/altera_testbench_packet_rom/altera_testbench_packet.ver" in read mode.
# No such file or directory. (errno = ENOENT) : /build/swbuild/SJ/nightly/18.1std/625/l64/work/modelsim/eda/sim_lib/altera_mf.v(48976)
Its looking in entirely the wrong place for altera_mf.v and moreover, there is no such file as altera_testbench_packet.ver, if anything its altera_testbench_packet.v
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I get it ,altera_testbench_packet.ver is supposed to be created from the .mif file by altera_mf.v.
I changed my script to the attachment and now I get:
# No such file or directory. (errno = ENOENT) : C:/intelFPGA_lite/18.1/quartus/eda/sim_lib/altera_mf.v(264)
# No such file or directory. (errno = ENOENT) : C:/intelFPGA_lite/18.1/quartus/eda/sim_lib/altera_mf.v(48977)..
The key has to be
No such file or directory. (errno = ENOENT) : C:/intelFPGA_lite/18.1/quartus/eda/sim_lib/altera_mf.v(264) - but there is!!!
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Yours works even with Quartus 18.1 which is what I am using.
The difference has to be I have a VHDL project and my ROM is part of the testbench file.
I have to use a tcl script file to persuade Modelsim to compile the ROM first because of that.(tb.tcl)
The issue has to be the vsim command or the fact I am using a MAX10.
I attach my project.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Now this is weird - I tried that it still didnt work.
I even downloaded the Modelsim Starter from Quartus 20.1 - same version as you, but i get same fault.
See attached transcript.
Looks like you are running Linux and I am running Windows 10. Do you have a Windows machine?
I f I were to try and learn Questa - it looks like I would need a license.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Yes I reinstalled Modelsim Starter edition 18.1 and tried version 20.1.
Where do we go from here?
I even went to the self service centre to get a free node locked license for Questa but the license didnt get recognised even though I set LM_LICENSE in the environmental variable. Thats another issue!
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I fixed it.. I deleted all versions of modelsim.ini and retried , now it works. Not sure what setting was making it go wrong though.
Thanks for your help.
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
