17268 Discussions
Modelsim "Types do not match"
Hi, I've wrote VHDL code, and also a testbench. Its my first attempt writing testbench so go easy please. I think it's correct but Modelsim keeps giving errors; I have tried numerous times with no joy.
This is top level:
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity quarter_round is generic(l:integer:=9); port(y : in unsigned(127 downto 0); z : out unsigned( 127 downto 0) ); end quarter_round; Architecture quarter_round_arch of quarter_round is component rtleft is generic(l:integer); port( a: in unsigned( 31 downto 0); b: out unsigned( 31 downto 0)); end component; signal y0 : unsigned( 31 downto 0); signal y1 : unsigned( 31 downto 0); signal y2 : unsigned( 31 downto 0); signal y3 : unsigned( 31 downto 0); signal i1,i2,i3,i4 :unsigned( 31 downto 0); signal j1,j2,j3,j4 :unsigned( 31 downto 0); signal z0,z1,z2,z3 :unsigned( 31 downto 0); begin y0 <=y(127 downto 96); y1 <=y(95 downto 64); y2 <=y(63 downto 32); y3 <=y(31 downto 0); i1<=y0+y3; r1:rtleft generic map(7) port map(i1,j1); z1<=j1 xor y1; i2<=z1+y0; r2:rtleft generic map(9) port map(i2,j2); z2<=j2 xor y2; i3<=z2+z1; r3:rtleft generic map(13) port map(i3,j3); z3<=j3 xor y3; i4<=z3+z2; r4:rtleft generic map(18) port map(i4,j4); z0<=j4 xor y0; z<=z0&z1&z2&z3; end quarter_round_arch;
Component 'rtleft' :
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity rtleft is generic (l:integer:=7); port( a: in unsigned( 31 downto 0); b: out unsigned( 31 downto 0)); end rtleft; architecture dataflow of rtleft is begin b<=a(31-l downto 0)& a(31 downto 31-l+1); end dataflow;
And the failing testbench:
LIBRARY ieee; USE ieee.std_logic_1164.all; USE ieee.numeric_std.all; ENTITY quarter_round_vhd_tst IS END quarter_round_vhd_tst; ARCHITECTURE test of quarter_round_vhd_tst IS COMPONENT quarter_round PORT ( y : IN STD_LOGIC_VECTOR(127 DOWNTO 0); z : OUT STD_LOGIC_VECTOR(127 DOWNTO 0) ); END COMPONENT; SIGNAL clk : bit := '0'; SIGNAL reset : bit := '0'; SIGNAL y : STD_LOGIC_VECTOR(127 DOWNTO 0); SIGNAL z : STD_LOGIC_VECTOR(127 DOWNTO 0); BEGIN DUT : quarter_round PORT MAP ( y => y, z => z ); y <= x"201f1e1d1c1b1a191817161514131211"; PROCESS BEGIN clk <= '0' ; wait for 10 ns; z <= y ; clk <= '1'; wait for 10 ns; END PROCESS; END test;
The error in modelsim " Types do not match between component and entity for port "y".
Again, I think the testbench is correct. Looking to input a 128 bit value for y and view the result (of z) on the wave.
hi.
In entity quarter_round you declared port y as unsigned. When you declared the component in the testbench, you declared the port as std_logic_vector. Usually the entity ports are of type std_logic or std_logic_vector.
thanks for your reply. I edited the entity quarterround and Modelsim allows me to simulate. I changed all to unsigned
It compiles in Modelsim by no output for z.
What is ModelSim showing? Is z in 'U' state?
https://www.alteraforum.com/forum/attachment.php?attachmentid=8866
I have made progress, output still incorrect though....
Please, post the entire quartus project ( zipped ). May be I give a better answer.
Thanks, thats it.
The modelsim tb file is .vht, in simulation.
Nothing like a good testbench...
Thanks! I'll try it out now
