17258 Discussions
Modelsim won't compiles VHDL -> Unexpected signal: 11
Hi Altera,
some Modelsim versions (10.3c and 10.1e) won't completely compile the following VHDL code.
library ieee; use ieee.std_logic_1164.all; entity x is generic (signal_count : natural := 1); port (clock : in std_logic); end entity; architecture rtl of x is type t_signal_array is array (signal_count - 1 downto 0) of std_logic_vector (2 downto 0); type reg_mclk_t is record ddr_chain : t_signal_array; output : std_logic_vector(signal_count - 1 downto 0); end record; signal mclk_r : reg_mclk_t; signal mclk_r_in : reg_mclk_t; begin MCLK_PROC: process (clock, mclk_r_in) begin if rising_edge (clock) then mclk_r.ddr_chain(signal_count - 1 downto 0)(2 downto 1) <= mclk_r_in.ddr_chain(signal_count - 1 downto 0)(2 downto 1); -- this line results in# ** Fatal: Unexpected signal: 11. --mclk_r.ddr_chain(signal_count - 1 downto 0) <= mclk_r_in.ddr_chain(signal_count - 1 downto 0); -- this works --mclk_r.ddr_chain(signal_count - 1 downto 0)(1) <= mclk_r_in.ddr_chain(signal_count - 1 downto 0)(1); -- this works --mclk_r.ddr_chain(signal_count - 1 downto 0)(2) <= mclk_r_in.ddr_chain(signal_count - 1 downto 0)(2); -- this works mclk_r.output <= mclk_r_in.output; end if; end process; end rtl;
Syntax checking passes all verifications, but when it comes to writing the library data to file system compile process stops with following message.
--- Quote Start ---
# vcom -work work -2002 -explicit -stats=none C:/work/VHDL-Sims/Test_unexpectedSignal.vhd# Model Technology ModelSim ALTERA vcom 10.3c Compiler 2014.09 Sep 20 2014# -- Loading package STANDARD# -- Loading package TEXTIO# -- Loading package std_logic_1164# -- Compiling entity x# -- Compiling architecture rtl of x# ** Fatal: Unexpected signal: 11.# ** Error: C:/work/VHDL-Sims/Test_unexpectedSignal.vhd(34): VHDL Compiler exiting
--- Quote End ---
Library view of ModelSim shows the new entity inside the library. However elaborating this entity and loading it into a simulation fails.
Even the library files on disk won't be created, thus elaboration can't find them.
Is there a specific reason for this or is it just a bug in ModelSim?
Looks like a Modelsim bug. Fatals like that without a decent explanation usually are.
Have you tried 10.4c? (the latest version)
If it still fails with latest you need to raise a ticket with mentor (not altera)
Thank you for the clarification. I wasn't sure if modelsim altera edition is managed by altera or by mentor.
I haven't got the 10.4c for now, but testing with 10.4b shows the same behavior.
Let's see what mentor says to this.
Ive compiled it in Questa 10.4c and 10.3c and didnt see a problem
Have you tried compiling in a clean folder?
How are you compiling the file?
Interesting that Questa doesn't have this problem.
So far i tried to compile it within a ModelSim project, outside a project file environment and into a clean newly created work library.
It doesn't changes the result and always comes up with the signal 11.
Only if i change the source from the double array range code to a single array access with individual bit access it compiles.
The questa ref manual gives exit 11 as "11 General language syntax error"
Again - this is a defect. You need to raise the issue with altera.
Ok thank you for your support. I just filed an service request to altera.
