17240 討論
Modifying internal components Parameters in a Sub-System Package (QCP)
Bala-Mookkiah
初學者
2,660 檢視
Hi I followed the instructions in online documents and youtube videos on how to add run_system_script for modifying internal components Parameters of a Sub-System Package (QCP) but so far I am not able to successfully modify it. I m hitting two main issues
1. "No Parameter Found" error when loading the QCP in QSYS. I am using internal parameter name but the system is not able to find it
2. load_component and save_component commands in the script is making the component fail to load in qsys.
Any help will be appreciated
Here is the subsystem package script
package require -exact qsys 25.1
set_package_property NAME "rpss_ssd"
set_package_property DISPLAY_NAME "rpss_ssd"
set_package_property VERSION "1.5"
set_package_property GROUP ""
set_package_property DESCRIPTION ""
set_package_property ELABORATION_CALLBACK elaboration_callback
set_package_property EXTRACTION_CALLBACK extraction_callback
set_package_property UNLOCKABLE true
add_fileset synth_fileset QUARTUS_SYNTH fileset_callback "Quartus Synthesis Fileset"
add_fileset sim_verilog_fileset SIM_VERILOG fileset_callback "Simulation Verilog Fileset"
proc elaboration_callback {} {
    enable_all_instances
    run_system_script TEXT {
       set args $__run_system_script_args_list__
       set args_len [llength $args]
       for {set i 0} {$i < $args_len} {incr i} {
            set param [lindex $args $i]
            set val [lindex $args [incr i]]
            send_message "Info" "val: $val"
            load_component rpss_0
            set_component_parameter_value QUEUE_MEM_BASE_ADDRESS $val
            save_component
        auto_assign_system_base_addresses
        sync_sysinfo_parameters
        save_system
        } [ list ADDR 0x10000 ]
    # disable_instance clock_in
    # disable_instance reset_in
    # disable_instance rpss_0
    # disable_instance rtile_dummy_0
proc extraction_callback {} {
    extract_modules
proc fileset_callback { output_name } {
    generate_all_instances
標籤 (1)
0 積分
14 回應
Bala-Mookkiah
初學者
2,646 檢視
BTW, This is a custom IP component which has verilog style PARAMETERS in the source code
sstrell
榮譽貢獻者 III
2,617 檢視
Can you clarify the structure here?  You've created a package named rpss_ssd.qcp.  What components are inside this package and how are they connected?  Show the New Packaged Subsystem dialog box if you can (right-click the .qcp in the IP catalog and choose to Edit it).
Or maybe it's as simple as QUEUE_MEM_BASE_ADDR vs. QUEUE_MEM_BASE_ADDRESS.
Bala-Mookkiah
初學者
2,361 檢視
Hi sstrell,
Thanks for looking into my issue and prompt response. I tried both QUEUE_MEM_BASE_ADDR vs. QUEUE_MEM_BASE_ADDRESS, but it didn't help. QUEUE_MEM_BASE_ADDRESS is the internal name, and I should use this according to the document. I attached a screenshot of the RSS_SSD QCP internals. rpss_0 is a custom IP (RTL written by me) with HDL parameters. They are configured and exported correctly, as shown in the _hw.tcl. I tried writing a similar script to existing Intel IPs in the IP catalog, and that worked. I am wondering if I need to do anything special in my custom component to configure the parameters in the qcp system.
add_parameter QUEUE_MEM_BASE_ADDRESS STD_LOGIC_VECTOR 268435456 ""
set_parameter_property QUEUE_MEM_BASE_ADDRESS DEFAULT_VALUE 268435456
set_parameter_property QUEUE_MEM_BASE_ADDRESS DISPLAY_NAME QUEUE_MEM_BASE_ADDR
set_parameter_property QUEUE_MEM_BASE_ADDRESS WIDTH 32
set_parameter_property QUEUE_MEM_BASE_ADDRESS UNITS None
set_parameter_property QUEUE_MEM_BASE_ADDRESS DESCRIPTION ""
set_parameter_property QUEUE_MEM_BASE_ADDRESS AFFECTS_GENERATION false
set_parameter_property QUEUE_MEM_BASE_ADDRESS HDL_PARAMETER true
set_parameter_property QUEUE_MEM_BASE_ADDRESS TRANSFORM_PARAMETER false
set_parameter_property QUEUE_MEM_BASE_ADDRESS EXPORT true
sstrell
榮譽貢獻者 III
2,268 檢視
Did you include the _hw.tcl file under Additional Files when creating the .qcp?  All files relating to custom IP must be included in the package.
FYI, windows key + shift + S for a screenshot will be much easier (and clearer) than taking screenshots with your phone.
Bala-Mookkiah
初學者
2,266 檢視
Yes I do. The rpss_ssd package is normall working with full functionality. I am just not able to set component level parameters. attached screen shot of the 'addition_file" tab.
sstrell
榮譽貢獻者 III
2,240 檢視
In my .qcp ss.tcl script, I included string matching for the name of the parameter.  So yours would look like this:
if {[string match $param "QUEUE_MEM_BASE_ADDRESS"]}{
          save_component
I don't know if this will do anything for you.  I put this in because I only wanted a single parameter to appear in the parameter editor for when the .qcp file was added to the system.
Bala-Mookkiah
初學者
2,235 檢視
Yes, just added the if condition, I am still seeing the original error
Error: set_component_parameter_value QUEUE_MEM_BASE_ADDRESS 0x1F000: No parameter named QUEUE_MEM_BASE_ADDRESS in rpss_0.
My qcp script
        if {[string match $param "QUEUE_MEM_BASE_ADDRESS"]} {
            save_component
} [ list QUEUE_MEM_BASE_ADDRESS 0x1F000 ]
Bala-Mookkiah
初學者
2,156 檢視
I am wondering about the RPSS custom IP. When it is getting instantiated, I don't see Quartus instantiating with the HDL parameters. Even though it detected the parameters in the create component analysis stage and has all the parameters properly listed in rpss_hw.tcl. So I am wondering if there are any other settings that I am missing for the parameters of the custom IP that need to be set for the detection of parameters correctly by Quartus/Platform Designer.
Instantiation of RPSS does not have parameters
rp_ss rpss_0 (
.hip_clk                    (clock_in_out_clk_clk),                                    //   input,    width = 1,               hip_clock_in.clk
.sys_clk                    (clock_in_out_clk_clk),                                    //   input,    width = 1,                 sys_clk_in.clk
.slow_clk                   (clock_in_out_clk_clk),                                    //   input,    width = 1,                slow_clk_in.clk
.ip_rst_n                   (reset_in_out_reset_reset),                                //   input,    width = 1,                   ip_rst_n.reset_n
.sys_rstn                   (reset_in_out_reset_reset),                                //   input,    width = 1,                   sys_rstn.reset_n
.reset_status               (rtile_dummy_0_r_tile_reset_status_n_reset),               //   input,    width = 1,      R_Tile_reset_status_n.reset_n
.slow_reset_status          (rtile_dummy_0_r_tile_slow_reset_status_n_reset),
whereas some existing Intel IPs are instantiated with parameters
altera_reset_controller #(
.NUM_RESET_INPUTS          (1),
.OUTPUT_RESET_SYNC_EDGES   ("both"),
.SYNC_DEPTH                (2),
.RESET_REQUEST_PRESENT     (0),
.RESET_REQ_WAIT_TIME       (1),
.MIN_RST_ASSERTION_TIME    (3),
.RESET_REQ_EARLY_DSRT_TIME (1),
.USE_RESET_REQUEST_IN0     (0),
.USE_RESET_REQUEST_IN1     (0),
.USE_RESET_REQUEST_IN2     (0),
in rpss_hw.tcl
add_parameter QUEUE_MEM_BASE_ADDRESS STRING "64'h0001_0000_0000_0000"
set_parameter_property QUEUE_MEM_BASE_ADDRESS DEFAULT_VALUE "64'h0001_0000_0000_0000"
set_parameter_property QUEUE_MEM_BASE_ADDRESS DISPLAY_NAME QUEUE_MEM_BASE_ADDRESS
ShengN_Intel
員工
1,766 檢視
If you locate the .v file in the synth folder, the instantiation showing the parameters right?
Sheng
Bala-Mookkiah
初學者
1,041 檢視
Hi Thanks for your response. I am still not able to solve this problem and would really appreciate the community to help me resolve this issue
This is my actual RTL module
module rp_ss
parameter RX_AFIFO_DEPTH = 512,
parameter RCB_64B_128B = 0, //0:64B 1:128B
parameter MAX_PYLD_SIZE = 13'd512,
// Two-channel memory architecture
parameter QUEUE_MEM_BASE_ADDRESS = 64'h0001_0000_0000_0000,
parameter QUEUE_MEM_SIZE = 64'h0000_1000_0000_0000, // 256GB
parameter DATA_MEM_BASE_ADDRESS = 64'h0004_0000_0000_0000,
parameter DATA_MEM_SIZE = 64'h0003_0000_0000_0000 // 768GB
This is the generated code
module rpss_0 #(
parameter       MAX_PYLD_SIZE          = 512,
parameter[63:0] QUEUE_MEM_BASE_ADDRESS = 64'b0000000000000000000000000000000000110000000000000000000000000000,
parameter[63:0] QUEUE_MEM_SIZE         = 64'b0000000000000000000000000000000000000000000000001010000000000000,
parameter[63:0] DATA_MEM_BASE_ADDRESS  = 64'b0000000000000000000000000000000000100000000000000000000000000000,
parameter[63:0] DATA_MEM_SIZE          = 64'b0000000000000000000000000000000000000000000100000000000000000000
rp_ss #(
.RX_AFIFO_DEPTH         (RX_AFIFO_DEPTH),
.RCB_64B_128B           (RCB_64B_128B),
.MAX_PYLD_SIZE          (MAX_PYLD_SIZE),
.QUEUE_MEM_BASE_ADDRESS (QUEUE_MEM_BASE_ADDRESS),
.QUEUE_MEM_SIZE         (QUEUE_MEM_SIZE),
.DATA_MEM_BASE_ADDRESS  (DATA_MEM_BASE_ADDRESS),
.DATA_MEM_SIZE          (DATA_MEM_SIZE)
) rpss_0
ShengN_Intel
員工
1,001 檢視
Seem like the generated code already has parameter QUEUE_MEM_BASE_ADDRESS?
Sheng
Bala-Mookkiah
初學者
361 檢視
I am not following your question. The generated code supposed to have the parameters or not?
ShengN_Intel
員工
294 檢視
The generated code should have parameters. Seems like your generated code got the parameters as well.
Sheng
Bala-Mookkiah
初學者
201 檢視
Ok. Any idea why the QCP instantiation is failing then?
回覆
