Объявления
17267 Обсуждение
Modifying internal components Parameters in a Sub-System Package (QCP)
Bala-Mookkiah
Начинающий
3 734Просмотр.
Hi I followed the instructions in online documents and youtube videos on how to add run_system_script for modifying internal components Parameters of a Sub-System Package (QCP) but so far I am not able to successfully modify it. I m hitting two main issues
1. "No Parameter Found" error when loading the QCP in QSYS. I am using internal parameter name but the system is not able to find it
2. load_component and save_component commands in the script is making the component fail to load in qsys.
Any help will be appreciated
Here is the subsystem package script
package require -exact qsys 25.1
set_package_property NAME "rpss_ssd"
set_package_property DISPLAY_NAME "rpss_ssd"
set_package_property VERSION "1.5"
set_package_property GROUP ""
set_package_property DESCRIPTION ""
set_package_property ELABORATION_CALLBACK elaboration_callback
set_package_property EXTRACTION_CALLBACK extraction_callback
set_package_property UNLOCKABLE true
add_fileset synth_fileset QUARTUS_SYNTH fileset_callback "Quartus Synthesis Fileset"
add_fileset sim_verilog_fileset SIM_VERILOG fileset_callback "Simulation Verilog Fileset"
proc elaboration_callback {} {
    enable_all_instances
    run_system_script TEXT {
       set args $__run_system_script_args_list__
       set args_len [llength $args]
       for {set i 0} {$i < $args_len} {incr i} {
            set param [lindex $args $i]
            set val [lindex $args [incr i]]
            send_message "Info" "val: $val"
            load_component rpss_0
            set_component_parameter_value QUEUE_MEM_BASE_ADDRESS $val
            save_component
        auto_assign_system_base_addresses
        sync_sysinfo_parameters
        save_system
        } [ list ADDR 0x10000 ]
    # disable_instance clock_in
    # disable_instance reset_in
    # disable_instance rpss_0
    # disable_instance rtile_dummy_0
proc extraction_callback {} {
    extract_modules
proc fileset_callback { output_name } {
    generate_all_instances
Метки (1)
0 баллов
16 Ответы
Bala-Mookkiah
Начинающий
3 720Просмотр.
BTW, This is a custom IP component which has verilog style PARAMETERS in the source code
sstrell
Почетный участник III
3 691Просмотр.
Can you clarify the structure here?  You've created a package named rpss_ssd.qcp.  What components are inside this package and how are they connected?  Show the New Packaged Subsystem dialog box if you can (right-click the .qcp in the IP catalog and choose to Edit it).
Or maybe it's as simple as QUEUE_MEM_BASE_ADDR vs. QUEUE_MEM_BASE_ADDRESS.
Bala-Mookkiah
Начинающий
3 435Просмотр.
Hi sstrell,
Thanks for looking into my issue and prompt response. I tried both QUEUE_MEM_BASE_ADDR vs. QUEUE_MEM_BASE_ADDRESS, but it didn't help. QUEUE_MEM_BASE_ADDRESS is the internal name, and I should use this according to the document. I attached a screenshot of the RSS_SSD QCP internals. rpss_0 is a custom IP (RTL written by me) with HDL parameters. They are configured and exported correctly, as shown in the _hw.tcl. I tried writing a similar script to existing Intel IPs in the IP catalog, and that worked. I am wondering if I need to do anything special in my custom component to configure the parameters in the qcp system.
add_parameter QUEUE_MEM_BASE_ADDRESS STD_LOGIC_VECTOR 268435456 ""
set_parameter_property QUEUE_MEM_BASE_ADDRESS DEFAULT_VALUE 268435456
set_parameter_property QUEUE_MEM_BASE_ADDRESS DISPLAY_NAME QUEUE_MEM_BASE_ADDR
set_parameter_property QUEUE_MEM_BASE_ADDRESS WIDTH 32
set_parameter_property QUEUE_MEM_BASE_ADDRESS UNITS None
set_parameter_property QUEUE_MEM_BASE_ADDRESS DESCRIPTION ""
set_parameter_property QUEUE_MEM_BASE_ADDRESS AFFECTS_GENERATION false
set_parameter_property QUEUE_MEM_BASE_ADDRESS HDL_PARAMETER true
set_parameter_property QUEUE_MEM_BASE_ADDRESS TRANSFORM_PARAMETER false
set_parameter_property QUEUE_MEM_BASE_ADDRESS EXPORT true
sstrell
3 342Просмотр.
Did you include the _hw.tcl file under Additional Files when creating the .qcp?  All files relating to custom IP must be included in the package.
FYI, windows key + shift + S for a screenshot will be much easier (and clearer) than taking screenshots with your phone.
Bala-Mookkiah
Начинающий
3 340Просмотр.
Yes I do. The rpss_ssd package is normall working with full functionality. I am just not able to set component level parameters. attached screen shot of the 'addition_file" tab.
sstrell
3 314Просмотр.
In my .qcp ss.tcl script, I included string matching for the name of the parameter.  So yours would look like this:
if {[string match $param "QUEUE_MEM_BASE_ADDRESS"]}{
          save_component
I don't know if this will do anything for you.  I put this in because I only wanted a single parameter to appear in the parameter editor for when the .qcp file was added to the system.
Bala-Mookkiah
Начинающий
3 309Просмотр.
Yes, just added the if condition, I am still seeing the original error
Error: set_component_parameter_value QUEUE_MEM_BASE_ADDRESS 0x1F000: No parameter named QUEUE_MEM_BASE_ADDRESS in rpss_0.
My qcp script
        if {[string match $param "QUEUE_MEM_BASE_ADDRESS"]} {
            save_component
} [ list QUEUE_MEM_BASE_ADDRESS 0x1F000 ]
Bala-Mookkiah
Начинающий
3 230Просмотр.
I am wondering about the RPSS custom IP. When it is getting instantiated, I don't see Quartus instantiating with the HDL parameters. Even though it detected the parameters in the create component analysis stage and has all the parameters properly listed in rpss_hw.tcl. So I am wondering if there are any other settings that I am missing for the parameters of the custom IP that need to be set for the detection of parameters correctly by Quartus/Platform Designer.
Instantiation of RPSS does not have parameters
rp_ss rpss_0 (
.hip_clk                    (clock_in_out_clk_clk),                                    //   input,    width = 1,               hip_clock_in.clk
.sys_clk                    (clock_in_out_clk_clk),                                    //   input,    width = 1,                 sys_clk_in.clk
.slow_clk                   (clock_in_out_clk_clk),                                    //   input,    width = 1,                slow_clk_in.clk
.ip_rst_n                   (reset_in_out_reset_reset),                                //   input,    width = 1,                   ip_rst_n.reset_n
.sys_rstn                   (reset_in_out_reset_reset),                                //   input,    width = 1,                   sys_rstn.reset_n
.reset_status               (rtile_dummy_0_r_tile_reset_status_n_reset),               //   input,    width = 1,      R_Tile_reset_status_n.reset_n
.slow_reset_status          (rtile_dummy_0_r_tile_slow_reset_status_n_reset),
whereas some existing Intel IPs are instantiated with parameters
altera_reset_controller #(
.NUM_RESET_INPUTS          (1),
.OUTPUT_RESET_SYNC_EDGES   ("both"),
.SYNC_DEPTH                (2),
.RESET_REQUEST_PRESENT     (0),
.RESET_REQ_WAIT_TIME       (1),
.MIN_RST_ASSERTION_TIME    (3),
.RESET_REQ_EARLY_DSRT_TIME (1),
.USE_RESET_REQUEST_IN0     (0),
.USE_RESET_REQUEST_IN1     (0),
.USE_RESET_REQUEST_IN2     (0),
in rpss_hw.tcl
add_parameter QUEUE_MEM_BASE_ADDRESS STRING "64'h0001_0000_0000_0000"
set_parameter_property QUEUE_MEM_BASE_ADDRESS DEFAULT_VALUE "64'h0001_0000_0000_0000"
set_parameter_property QUEUE_MEM_BASE_ADDRESS DISPLAY_NAME QUEUE_MEM_BASE_ADDRESS
ShengN_Intel
Сотрудник
2 840Просмотр.
If you locate the .v file in the synth folder, the instantiation showing the parameters right?
Sheng
Bala-Mookkiah
Начинающий
2 115Просмотр.
Hi Thanks for your response. I am still not able to solve this problem and would really appreciate the community to help me resolve this issue
This is my actual RTL module
module rp_ss
parameter RX_AFIFO_DEPTH = 512,
parameter RCB_64B_128B = 0, //0:64B 1:128B
parameter MAX_PYLD_SIZE = 13'd512,
// Two-channel memory architecture
parameter QUEUE_MEM_BASE_ADDRESS = 64'h0001_0000_0000_0000,
parameter QUEUE_MEM_SIZE = 64'h0000_1000_0000_0000, // 256GB
parameter DATA_MEM_BASE_ADDRESS = 64'h0004_0000_0000_0000,
parameter DATA_MEM_SIZE = 64'h0003_0000_0000_0000 // 768GB
This is the generated code
module rpss_0 #(
parameter       MAX_PYLD_SIZE          = 512,
parameter[63:0] QUEUE_MEM_BASE_ADDRESS = 64'b0000000000000000000000000000000000110000000000000000000000000000,
parameter[63:0] QUEUE_MEM_SIZE         = 64'b0000000000000000000000000000000000000000000000001010000000000000,
parameter[63:0] DATA_MEM_BASE_ADDRESS  = 64'b0000000000000000000000000000000000100000000000000000000000000000,
parameter[63:0] DATA_MEM_SIZE          = 64'b0000000000000000000000000000000000000000000100000000000000000000
rp_ss #(
.RX_AFIFO_DEPTH         (RX_AFIFO_DEPTH),
.RCB_64B_128B           (RCB_64B_128B),
.MAX_PYLD_SIZE          (MAX_PYLD_SIZE),
.QUEUE_MEM_BASE_ADDRESS (QUEUE_MEM_BASE_ADDRESS),
.QUEUE_MEM_SIZE         (QUEUE_MEM_SIZE),
.DATA_MEM_BASE_ADDRESS  (DATA_MEM_BASE_ADDRESS),
.DATA_MEM_SIZE          (DATA_MEM_SIZE)
) rpss_0
ShengN_Intel
Сотрудник
2 075Просмотр.
Seem like the generated code already has parameter QUEUE_MEM_BASE_ADDRESS?
Sheng
Bala-Mookkiah
Начинающий
1 435Просмотр.
I am not following your question. The generated code supposed to have the parameters or not?
ShengN_Intel
Сотрудник
1 368Просмотр.
The generated code should have parameters. Seems like your generated code got the parameters as well.
Sheng
Bala-Mookkiah
Начинающий
1 275Просмотр.
Ok. Any idea why the QCP instantiation is failing then?
ShengN_Intel
Сотрудник
817Просмотр.
When you generated the .qcp file, there's one auto generated code right?
Is that the generated code that you share?
Possible provide the .qcp file for testing? You may send privately to my email.
Sheng
ShengN_Intel
Сотрудник
226Просмотр.
May I know any further concern?
Sheng
Ответить
