17259 Discussions
Multi-phase data recovery design constraints
L982123
I have a design where an input is being oversampled by using multiple phase outputs from a PLL.  To make this work I need to ensure that the skew between the input and each sampling register is at a minimum.  I have tried using the set_max_skew constraint, but this seems to have no effect on the fitter results.  Is there a known method for implementing this correctly using design constraints?
KhaiChein_Y_Intel
Does the skew value in the report_skew report less than the value you set using set_max_skew? Can you check if this constraint is being ignored and listed in the Ignored Constraints report? Have you tried setting the clock to global signal?
KhaiY
KhaiChein_Y_Intel
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
KhaiY
