Hello.
I am trying to make a mac component. Everything is fine, until I put acc (my accumulator) receiving the output value. The strange thing is that Quartus sythetize it, but Modelsim acuse a multi-source and responde with X in output value. Do you guys have any ideas? Here is the code: library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; ENTITY main IS generic ( size : integer := 4; port ( clk : in std_logic; rst : in std_logic; a_i : in std_logic_vector(size-1 downto 0); b_i : in std_logic_vector(size-1 downto 0); out_o : out std_logic_vector(2*size-1 downto 0) ); END main; ARCHITECTURE bhv OF main IS COMPONENT mac generic ( width : integer); port ( clk : in std_logic; rst : in std_logic; a_i : in std_logic_vector(width-1 downto 0); b_i : in std_logic_vector(width-1 downto 0); acc : in std_logic_vector(2*width-1 downto 0); out_sig : out std_logic_vector(2*width-1 downto 0) ); END COMPONENT; signal acc, out_sig, out_acc : std_logic_vector(2*size-1 downto 0) := (others => '0'); BEGIN mac1: mac GENERIC MAP (size) PORT MAP (clk, rst, a_i, b_i, acc, out_sig); reg_out : process(clk, rst) begin if rst = '1' then out_o <= (others => '0'); elsif clk'event and clk = '1' then out_o <= out_sig; end if; end process; reg_acc : process(clk, rst) begin if rst = '1' then acc <= (others => '0'); elsif clk'event and clk = '1' then acc <= out_sig; end if; end process; END bhv;連結已複製
9 回應
Try to replace this line
mac1 : mac GENERIC MAP (size) PORT MAP (clk, rst, a_i, b_i, acc, out_sig);
With this
mac1 : mac
GENERIC MAP (
width => size
PORT MAP (
clk => clk,
rst => rst,
a_i => a_i,
b_i => b_i,
acc => acc,
out_sig => out_sig
If the entity of "mac" has a different signal order then your component declaration you avoid problems with explicitly mapping each signal this way.
https://www.alteraforum.com/forum/attachment.php?attachmentid=6542
I attached the response. At a certain moment, value is X. Also, the result is stable, it isnt summing as required.In the signal declaration you assign (OTHERS => '0') to "out_sig" try to replace your signal declaration:
SIGNAL acc, out_sig, out_acc : std_logic_vector(2*size-1 DOWNTO 0) := (OTHERS => '0');
with this code:
SIGNAL acc : std_logic_vector(2*size-1 DOWNTO 0) := (OTHERS => '0');
SIGNAL out_acc : std_logic_vector(2*size-1 DOWNTO 0) := (OTHERS => '0');
SIGNAL out_sig : std_logic_vector(2*size-1 DOWNTO 0);
Currently I only can make an educated guess on behalf of your error description what may be wrong with your VHDL code.
The best way would be if I can replicate the problem on my side, but for this I would need the code your "mac" component and your testbench.
