And what problems are you having?
--- Quote Start --- And what problems are you having? --- Quote End --- Sorry, I forgot to write... Both ports appear to not send or receive any data if I use the mux.
have you simulated the design? does it work? have you tried signaltap to investigate the situation and see if all control is as you expected?
--- Quote Start --- have you simulated the design? does it work? have you tried signaltap to investigate the situation and see if all control is as you expected? --- Quote End --- Yes, seems to be working on the simulation, but I didn't try the signaltap. I used only a few times some years ago, so I need to re-learn about it.
![](/skins/images/DCC883141309A464C31AD18F1D8B9C6A/responsive_peak/images/icon_anonymous_message.png)
Topic Options
