17264 Discussions
NativeLink error when try to run RTL simulation
Chirs888
Get errors when try to run RTL simulation,
The report is:
Info: Start Nativelink Simulation process
Error: NativeLink did not detect any HDL files in the project
Error: NativeLink simulation flow was NOT successful
================The following additional information is provided to help identify the cause of error while running nativelink scripts=================
Nativelink TCL script failed with errorCode: NONE
Nativelink TCL script failed with errorInfo: NativeLink did not detect any HDL files in the project
(procedure "run_eda_simulation_tool" line 1)
invoked from within
"run_eda_simulation_tool eda_opts_hash"
Tool option setting is right and can run .vwf simulation.
Upload .vt file on simulation testbench setting, still error.
Please help me with this error.
THANKS!
sstrell
Way more info needed here.  What are your NativeLink settings?  What 3rd-party sim tool are you using and is the path to its executable set up correctly?  Does the Quartus project synthesize correctly?  What's your version of Quartus and target device?
Chirs888
Somehow it fixed after restart. Thank you.
ShengN_Intel
Probably the steps in this document https://www.intel.com/content/www/us/en/docs/programmable/683248/18-0/simulation-quick-start.html can help you understand the nativelink simulation setup flow.
Sheng
Chirs888
