- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
- Сообщить о недопустимом содержимом
I'm trying to run a simple "Hello World" program on Nios II.
I'm following these steps: https://www.intel.com/content/dam/support/us/en/programmable/support-resources/fpga-wiki/asset02/nios-ii-hello-world-a10.pdf
I've made to through all the steps of creating the design in platform designer, compiling, programming the design to the board (DE10-Lite), generating the BSP, and building the project in Eclipse with no issue. Even when I run the hardware configuration, I get no errors, but nothing prints to the Nios II Console. I've tried running a simple math program in the debugger, and it seems like the Nios CPU is executing instructions, but when it comes to printing to stdout, nothing shows up. When I open the run configuration window in the Target Connections section, I get the message "The expected Stdout device name does not match the selected target byte stream device name." How can I find the stdout device name? How can I find the selected target byte stream device name? How can I change either of these so that they match? I'm not sure how to fix this error or if it is even the source of why nothing is printing to stdout, but it's all I have right now. I'm using Quartus Lite Version 22.1
Any help is appreciated. Thanks.
Ссылка скопирована
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Show your BSP settings. Did you add the jtag UART component in Platform Designer?
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi there,
Any other suggestions? I still haven't debugged the issue.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello there,
Yes I'd still like help with this matter. Thanks.
Best,
allens1
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi allenS1,
Did you use the juart-terminal to perform the operation?
Here I tested with NiosV hello world. You can download the design from the below:
First program the .sof file of the design to the FPGA.
Then run the NiosV command shell. (niosv-shell)
Then download the hello worl application file into the design in the ready_to_test_file folder. (niosv-download app_hal2.elf)
Then perform:
niosv-download -g
niosv-download -r
juart-terminal
You will able to see the Hello world application running.
Aik Eu
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
For your current design screenshot from your previous comment.
I think you didnt connect the data_master to the juart Ip
Aik Eu
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi there,
I connected the data_master to jtag ip and I can see the "Hello World" printing to the console. Thanks so much!
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi allenS1,
Glad that the issue has been resolved. I will close the thread for now.
Aik Eu
- Отметить тему как новую
- Отметить тему как прочитанную
- Выполнить отслеживание данной Тема для текущего пользователя
- Закладка
- Подписаться
- Страница в формате печати
