公告
17268 讨论
Number of clock cycle consumed by division function offred by Quartus II ?
名誉分销商 II
2,757 次查看
Hello everyone, how many number of clock cycle will be consumed by division function offred by Quartus II to produce the result ? My input data width are 16 bit.
0 项奖励
11 回复数
名誉分销商 II
1,538 次查看
I don't know, but you could create it an measure. either in simulation or in implementation.
0 项奖励
名誉分销商 II
1,538 次查看
actually i dont have quartus software. I have xilinx ISE Design Suite. So i want to know about this before switching to Quartus II
0 项奖励
名誉分销商 II
1,538 次查看
Are you using a Xilinx Chip? or are you moving to altera chips?
Either way - you can just generate a divider core with a pipeline that should be configurable. You could set the number of clocks to 1 if you like. But usually, with 1 clock pipeline, the fmax would be so slow that you'll actually be able to compute values quicker with larger pipeline length.
0 项奖励
名誉分销商 II
1,538 次查看
You can also simulate your design in Modelsim Altera Starter edition which is free to check on the clock cycle.
0 项奖励
名誉分销商 II
1,538 次查看
if you have 16 bit width number and do division we assume you use the most fast division in most cases it is shift operation only.
After shifting you can correct your result according to remainder.
0 项奖励
名誉分销商 II
1,538 次查看
but for 16 bit its taking 16 clock cycle
0 项奖励
名誉分销商 II
1,538 次查看
that number of clocks it takes should be a parameter of the divider core when you generated the core.
0 项奖励
名誉分销商 II
1,538 次查看
is there any other way for division operation in minimum number of cycle?
0 项奖励
名誉分销商 II
1,538 次查看
Yes- generate a new divider core.
0 项奖励
名誉分销商 II
1,538 次查看
Sir, can you explain it please?
0 项奖励
名誉分销商 II
1,538 次查看
Go to the IP catalogue
Find the divider
Generate the core from the gui - one of the options is the latency./
0 项奖励
回复
