17268 Discussions
Ones counter using numeric_std inside process
I had an error while working on ones counter inside the process. I use numeric_std library. Here is the key part of the code.
signal one_buf:unsigned(7downto0);
signal out_buf:std_logic_vector(7downto0);
counter_one:process(out_buf1)
variable one_buf1 :unsigned(7downto0):=(others=>'0');
begin
for i in 0 to 7 loop
one_buf1 := one_buf1 +unsigned(out_buf(i));
endloop;
one_buf <= one_buf1;
end process counter_one;
The error message is Error(10305) cannot convert type "std_ulogic" to type "UNSIGNED". I do not understand what is wrong here.
Thanks in advance for the answers.
out_buf1(i) is a single bit. You need to make it into an array. something like:
one_buf1 := one_buf1 + ("" & out_buf(i));
--- Quote Start ---
--- Quote End ---
Thanks for the answer, Tricky.
I tried and then there are some other errors.
Error (10327): VHDL error at mess_extractor.vhd(278): can't determine definition of operator ""&"" -- found 4 possible definitions
Error (10647): VHDL type inferencing error at mess_extractor.vhd(278): type of expression is ambiguous - "std_ulogic_vector" or "std_logic_vector" are two possible matches
Can you comment on this too? Thanks!
try this:
one_buf1 := one_buf1 + unsigned'("" & out_buf(i))
