17241 Discussions
Porting from Xilinx to Altera
Mathiazhagan
Hi there,
 I want to convert a huge project which contains around 45 sub modules and around 44 ip cores of xilinx  from Xilinx to intel, Is there any way to convert else i have to do it from the scratch level.
How to define a parameter outside the module of a HDL Code in altera, Please share me the format for defining a keyword parameter in HDL Code.
Thanks in Advance
RichardTanSY_Altera
I believe I have provided the support/answer that you needed in order to proceed with your project. With that, this thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.
RichardTanSY_Altera
.qpf for Quartus Pro cant be opened with Quartus Standard so you will need to open a new project and copy the pro .qsf file to your new qsf file to add all the files.
Mathiazhagan
Dear RichardTanSY,
I opened a new project and added the .qsf file but am not able to view the files, could u please share me the individual files that u have converted instead of a single .qsf file, I will add all the converted files to the new project created and let me check.
With Regards,
V.Mathiazhagan
RichardTanSY_Altera
Richard Tan
Mathiazhagan
Dear Richard Tan,
Thanks a lot, I got the required support in order to proceed further in my work, The converted code is for Agilex, Will i able to use the agilex converted code to work on a cyclone 5 series boards.
With Regards,
V.Mathiazhagan
