17253 Discusiones
Possible places for Pin assignments for a design
Colaborador Distinguido II
1.235 Vistas
I have a general question on pin assignments for design.
What are the possible places to do pin assignments for any ALtera/ quartus FPGA design?
In one of the designs that I have, there are no pin assignments in qsf, qdf or sdc file. But when I open Pin Planner, I see there are assignments present under "Fitter Location". These are valid assignments for the design and not randomly chosen assignments. So, I was wondering if these were defined in the qsys or some other location.
Thanks in advance.
0 kudos
2 Respuestas
500 Vistas
They should always be in your .qsf. I believe Fitter Location is where it was placed in the previous compile, and only exists if you have a database. They do not drive the fitter on the next compile. You could go to Project -> Back-Annotate and lock them down, which will put them into the .qsf.
500 Vistas
Got it. Thank you very much Rysc :)
Responder
