I am trying to make a post config BSDL for the Cyclone II EP2C35F4847N, but the post configure file appears “syntax error” when import to the Boundary Scan library.
When open the *_new.bsdl file it looks like the generating with Quartus II was abort. So the new BSDL is not complete. I compared with the original BSDL and found there is no define for END of the BSDL and short of from 1400~1448.
I am wondering if the BSDLCustomizerv2-4.tcl script issue or my Quartus software issue.
Could you pls help send me a correct one so that I could continue to do the Boundary Scan test?
Attached pls find the pre-config BSDL of EP2C35, pin file, tcl script for cyclone II and “syntax error” post config BSDL for your reference.
Thank you!
Hi SYan6,
This should be the same question that has been address in the thread below:
Nooraini
