- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
By default, Quartus flattens all the logic, which makes it difficult for me to apply ASIC constraints to it. What I need is to preserve the hierarchy of some sub-blocks, so it's interface remains intact and constraints can be applied to it.
In Quartus II there were three options for this (Preserve Hierarchical Boundary -> Off / Relaxed / Firm), how do I do this in Quartus Prime (version 17.1.0)?
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi EPeet
You can see here, for example in Quartus Prime manual (https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/qts/archives/qts-qps-handbook-16-1.pdf)
"16.3.1 Partitions for Preserving Hierarchical Boundaries" -
Note: The Preserve Hierarchical Boundary logic option is available only in Quartus Prime software versions 8.1 and earlier. Altera recommends using design partitions if you want to preserve hierarchical boundaries through the synthesis and fitting process, because incremental compilation maintains the hierarchical boundaries of design partitions.
Hope that helps
Ivan
