- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
Hi all,
Ok, I found out that SDRAM keeps writing forever and never stop, when I call IOWR_32DIRECT(...) in SignalTap. When I look at Dev Board Cyclone II and it does show Write and Burst Terminate in SignalTap. My board is Cyclone III with MT48LC4M32B2-7. Maybe clock phase shift or something else. Thanks for read my post and help. SeanLink copiado
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
not much info, but yes, you will need to do a clock phase shift between the clock that is driving your SDRAM chip and the clock that is driving your SDRAM controller block. There is some latency though the SDRAM controller. This is not necessarily your problem though. You should be using two seperate clocks. You can have several clocks out of one PLL. They need to be the same clock rate, just delay one of them. You can do it by trial and error and find out what the upper and lower bounds are for proper operation then split the difference. If you give more info like what clock rate and how your SOPC architecture is setup it might help.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Thanks. I have sys_clk is 100mhz and sdram_clk is 133mhz...my phase shift is -3.5ns.
pll.c0 goes to sys_clk Nios 1/1 and 0deg pll.c1 goes to output sdram_clk 4/3 = 133mhz and -3.5ns pll.c2 goes to output sys_clk 1/1 and 0deg Thanks. Sean- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
You should also constrain your memory interface. It might not be even necessary to phase shift the clock is you provide proper constraints since the fitter might be able to compensate for the offchip timing.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Ok. Where can I get that information about constrain memory interface? Is there documents online to show me how? I've been looked into TimeQuest, but I don't know where to start... SDC, Create Clock, Set Input Delay... Set Output Delay...
How about I post my design, maybe you could take a look at it? Thanks, Sean- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
there is some info on constraining SOPC systems if you search on this blog. I can tell you that the clock phase shift is all that is necessary though.
Have you done a timing analysis? Are you passing timing with the SDRAM controller running at 133? I could barley get mine to run at 100Mhz on a CIII spd grade 8. Have you tried running all are you using a custom SDRAM controller or one that is preconfigured in SOPC builder?- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I did try custom and without custom for SDRAM controller in SOPC. In pll, I select Any for speed. I also tried to set sys_clk to 50mhz and sdram_clk to 50mhz and still no luck. I need to get this SDRAM working... bc my design already works on dev board with SGDMA -> FIFO -> FIFO -> SGDMA The weird thing is that when I write to sdram. It never stops. My look like this WRITE –----- -à Gone with the wind But actual should looks like this WRITE – NOP – PRECHARGE – NOP – ACTIVE Best regards, Sean- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
ok, i just looked in sopc, so the memory you are using is already setup, so your controller should be working.
I think you just need to get your clocking right. Let me understand your system. You have a Nios II and you have the memory in SOPC builder. And you have a PLL in SOPC or outside of SOPC? You basically need to have 1 clock that is driving the SDRAM controller from your PLL and then you need to have another clock that is exported out of your SOPC or top level file off the FPGA to the clock pin of the SDRAM. The clock that is driving the SDRAM should have a delay of around -3ns. You need to be doing a timing analysis and putting timing constraints in your design so that at a very minimum, quartus knows what clocks everything is running off of. In your .SDC file you should have something like this: create_clock -period 20.000 -name ext_clk [get_ports {clk50}] derive_pll_clocks derive_clock_uncertainty where clk50 is the name of your input clock pin that is driving the FPGA. and 20 is the period of that clock. In my case I have a 50Mhz osc hooked to my PLL input. If you have all of this and still can't get it to work it maybe a software problem or pin mapping problem.- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
also, in software, you can do something like this to test your memory.
alt_u32* sdram = (alt_u32*) SDRAM_BASE; where SDRAM_BASE is the base address of your SDRAM controller. You can find that in your system.h file. for(i=0;i<10000;i++) { sdram[i] = i; } then in the debugger, you can load sdram variable as an array and verify the result of your for loop.- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi spaugh,
I'm using sys_clk=50mhz, sdram=50mhz, and phase shift=0. When I do Generate SDC File From QSF, I do see the result like this create_clock -name {altera_reserved_tck} -period 100.000 -waveform { 0.000 50.000 } [get_ports {altera_reserved_tck}] create_clock -name {sys_clk} -period 10.000 -waveform { 0.000 5.000 } [get_ports {sys_clk}] create_clock -name {sdram_clk} -period 7.518 -waveform { 0.000 3.759 } [get_ports {sdram_clk}] Unconstrained Paths Summary Illegal Clocks 0 0 Unconstrained Clocks 0 0 Unconstrained Input Ports 35 35 Unconstrained Input Port Paths 195 195 Unconstrained Output Ports 56 56 Unconstrained Output Port Paths 88, 88 Thanks for your help. Sean- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi all,
I think I got my sys_clk right this time, I set sys_clk is 100mhz and sdram_clk is 133mhz. In my Nios II unsigned int i, w, r; for (i=5; i<8; i++) IOWR_32DIRECT(SDRAM_BASE, i, i); for (i=5; i<8; i++) r = IORD_32DIRECT(SDRAM_BASE, i); I see the write seems to work 5, 6, and 7, but when I read it back. I get 0. When you look at SignalTap, you see CS, RAS, CAS, WE (L, H, L, H) is for read 0. Geting close ... Best regards, Sean- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
sean, I don't think you will be able to get your system to meet timing with those clock rates. I think you will need to shoot for 100Mhz max on the sdram controller clocks. I tried looking at your pictures that you originally posted of your system, but they were too small to view. If you archive your project I will look at it when I have some free time. But I can tell you that unless you have a speed grade 6 chip, you aren't going to get the sdram controller to meet timing at 133Mhz. The chip is not capable of running that logic at that speed.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
If your system (including the CPU) is clocked at 100MHz and your SDRAM is at 133MHz are you sure you are not hindering your performance? For a 33MHz speed increase is it worth the extra 9-12 clock cycles for the clock crossing that you have inserted? So before trying to tune this memory interface I recommend asking yourself "do I really need my RAM operating this fast???"..... just a thought. The first two chapters go into more detail: http://www.altera.com/literature/hb/nios2/edh_ed5v1_03.pdf
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Thanks spaugh and BadOmen.
Even I tried (sys_clk=25mhz and sdram_clk=33mhz), I still couldn't get it working. In my Nios unsigned int i, w, r; for (i=5; i<8; i++) { IOWR_32DIRECT(SDRAM_BASE, i, i); usleep(20); } for (i=5; i<8; i++) r = IORD_32DIRECT(SDRAM_BASE, i); I see in signaltap... write 5 .... wait (20) write 6 .... wait (20) write 7 .... wait (20) ... So I think the write method seems working right. But when I read 5, 6, 7... I got 0, but I do see (CS, RAS, CAS, WE) L H L H on the lines. Thanks, Sean- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
You are performing unaligned accesses. The 'i' variable you are using as an offset in the 32-bit read/write IO macros needs to be multiples of 4 (bytes). I think you meant to access word offset 5, 6, 7 which means the offset for the macro needs to be 20, 24, 28
The fabric doesn't support unaligned accesses so I'm guessing you were actually accessing byte address 4 when you passed in 5, 6, 7. If you want to populate the SDRAM with an increment pattern and read it back try this: volatile unsigned long r; // you don't want the compiler to optimize out the read loop for (i = 0; i < SOMETHING; i++) IOWR_32DIRECT(SDRAM_BASE, i*4; i); for (i = 0; i < SOMETHING; i++) r = IORD_32DIRECT(SDRAM_BASE, i*4);- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Thanks BadOMen. I'm still the same problem. The zs_dq_to_and_from_sdram[0..31] always retuns 0 when I call read. But the write ok.
I also include the capture Write and Read Write CS, RAS, CAS, WE = L H L L Read CS, RAS, CAS, WE = L H L H In Nios i = 5; IOWR_32DIRECT(SDRAM_BASE, i*4, i); printf("Write: %x\n", i); usleep(10); i = 5; r = IORD_32DIRECT(SDRAM_BASE, i*4); printf(" Read: %x\n", r); Output Write: 5 Read: 0 ~Sean- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Just updated.
I just got a brand new board from hardware engineer. It seems to work with limit time, but it still fails. Nios code: volatile unsigned long w, r; unsigned int i; for (i=5; i<10; i++) { IOWR_32DIRECT(SDRAM_BASE, i*4, i); printf("Write: %x\n", i); usleep(1000); // Note: it only works with 1000. Not 10000 r = IORD_32DIRECT(SDRAM_BASE, i*4); printf(" Read: %x\n\n", r); } nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) Write: 5 Read: 5 Write: 6 Read: 6 Write: 7 Read: 7 Write: 8 Read: 8 Write: 9 Read: 9 With usleep(10000) nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) Write: 5 Read: ffffffff Write: 6 Read: ffffffff Write: 7 Read: ffffffff Write: 8 Read: ffffffff Write: 9 Read: ffffffff ~Sean- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
sean, why do you want to run your cpu and sdram at different rates?
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
