17266 Discussions
Problem in pin assignment
I m new with Quartus and I have project with CycloneIII.
The problem is when I try to connect the SSRAM it seems that not all pins indicated in the reference manual are assignable (eg: in the manual FPGA pin's A16 must be connected to sram A[2] but in the assignment this pin A16 is unavailable because it's dedicated to VCCIO7).
What can I do to connect the SSRAM?
Maybe the Manual refers to pin A16 of a different type of FPGA ?
But I use the manual provided with the cycloneIII
check under device settings in Quartus that this pin is not a dual purpose pin and assigned to the VCCIO rather then regular I/O
Don't rely on the manual for pin assignments, Altera usually makes errors in those. Look at the board schematics instead.
--- Quote Start ---
--- Quote End ---
be sure to file an SR and let Altera know about incorrect manuals. and also look at the Golden Top file which should have correct pin assignments done for you. :eek:
