17268 Discussions
Problem when compiling project in Quartus 13.0
Hi everyone!
I encounter a problem when I compile project in Quartus, namely Fitter was unsuccessful
Following picture is sub message from Compilation report of Quartus
http://www.alteraforum.com/forum/attachment.php?attachmentid=9714&stc=1
Please help me solve this problem!
Thank you so much!
Normally to help routability, the best thing to do is turn up the placement effort(assignments -> settings -> fitter -> More -> Placement Effort -> 4). A better placement also means less routing congestion and more likely to get a route. That's for the "generic" case though. In your case the two signals are control signals, and more importantly, have ~CLKENA0 appended to them. This is done when it goes through an altclkctrl block, which is how it gets onto a global signal(or regional/dual-regional, etc.). So it seems like you're running out of the underlying clock routing resources, which is not good. What device is this?
It's hard to diagnose more, but two thoughts:
1) Take the reset_synchronizer signal off a global. Just do:
set_instance_assignment -name GLOBAL_SIGNAL "OFF" -to blaa
and replace blaa with the full signal name for the ...altera_reset_synchronizer..., but without the ~CLKENA0 at the end. (I can't cut and paste from your sceen-shot).
2) Go to Global section and see if there are any other signals you can take off globals.
I'm not positive this is the issue, but taking a guess...
