Problem with ALTPLL
I use a ATLPLL IP In my design. This PLL has one input clock and one output clock.
The input clock is 62.5MHz. The PLL outputs an inverted clock.
I expected the clock max skew from inclk0(62.5MHz) to c0(inverted) is 0.5ns.
The post-sim waveform shows the skew is 10.7ns.
The ALTPLL's connections as below:
DPLL U_DPLL(
.inclk0 (clk_62M ),
.c0 (clk_62M_inv),
.locked (locked )
What's wrong with my design?
Any and all help is very much appreciated
Harris
Is PLL output configured as source synchronous?
How to configure the PLL's output?
Quartus II MegaWizard Plug-In Manager
OK
I will try it.
I have changed the PLL settings, but the problem is still exist.
My PLL current settings:
1. Use the feedback path inside the PLL
2. In normal mode
3. The source synchronous compensation mode si disabled by Quartus II
The c0 is used internal.
I believe Cris suggets to set it to source synchronous mode instead of normal mode (tick the selection just under normal mode)
The option In source-synchronous compensation mode is disabled by Quartus II.
I can not tick the selection.
My device is Cyclone.
