17261 Discussions
Programming Cyclone II kit with Quartus and Linux
I have been used to program my FPGA with Quartus 7.2 and Windows, but I am now required to do so with Linux, so I installed Quartus 11.0 with the Altera Installer, everything seemed to be fine, until I tried to load a simple program of mine : the USB cable is detected (it's called USB blaster variant [5-2] , but when I click "Start", nothing happens. What am I doing wrong ?
S
:( Still no replies.. I was wondering : maybe I need to change the rights of the USB dev file ? I just can't understand why it shows up and won't work. Or maybe I should try with a more stable version ? I'm clueless, so any idea, (even guesses) is welcome !
S
--- Quote Start ---
--- Quote End ---
Same problem, it shows USB Blaster Variant but at progress bar it says Failed :/
Ubuntu 11.04 here...
Any solution?
--- Quote Start ---
Any solution?
--- Quote End ---
Ubuntu 11.04 works fine with USB-Blasters. Look at the threads on the subject.
http://www.alteraforum.com/forum/showthread.php?t=32179
http://www.alteraforum.com/forum/showthread.php?t=31426
What is your 'variant', I assume some sort of clone? It should also work fine, but perhaps your udev rules are not setup correctly.
One caveat: USB-Blasters do not work from virtual machines (VirtualBox or VMWare) - at least when I last checked a few weeks ago. VirtualBox has just released 4.1.4, but I haven't tested it yet.
Cheers,
Dave
