Hi
i implemented a transceiver with the ALTGX megafunction and want to assign the pins (tx_dataout_sig[1...4]). The I/O Standard should be 1.4V PCML. (As seen in the assignments)
set_location_assignment IOBANK_QL1 -to tx_dataout_sig -disable
set_instance_assignment -name IO_STANDARD "1.4-V PCML" -to tx_dataout_sig -disable
set_location_assignment PIN_AD36 -to tx_dataout_sig
set_location_assignment PIN_AD37 -to "tx_dataout_sig(n)"
set_location_assignment PIN_AB36 -to tx_dataout_sig
set_location_assignment PIN_AB37 -to "tx_dataout_sig(n)"
set_location_assignment PIN_T36 -to tx_dataout_sig
set_location_assignment PIN_T37 -to "tx_dataout_sig(n)"
set_location_assignment PIN_P36 -to tx_dataout_sig
set_location_assignment PIN_P37 -to "tx_dataout_sig(n)"
set_instance_assignment -name BOARD_MODEL_TERMINATION_V "HALF VCCIO" -to tx_dataout_sig
set_instance_assignment -name IO_STANDARD "1.4-V PCML" -to "tx_dataout_sig(n)"
set_instance_assignment -name CKN_CK_PAIR ON -from tx_dataout_sig -to "tx_dataout_sig(n)"
But the signal displayed on my scope is only from 84mV to 212mV... So it's nothing about 1.4V PCML. Do I have to set any other settings? Thanks for your help! Thomas
Hi, i'm the colleague of thomas and i wrote the firmeware.
Here are some additional information about the transceiver configuration.- Protocol: Basic X4
- Transmitter only
- Effective datarate : 1720 Mbps
- inclk frequency : 430 MHz
- PLL bandwith: Auto
- VCCHTX: Auto
- Pre-emphasis pre-tap: 0
- Pre-emphasis first Post-tap: 0
- Pre-emphasis second post-tap: 0
- Self test mode: none
- low latency PCS mode is enabled
- No reconfiguration and loopbacks
u_tx_channel : tx_channel
port map
-- inputs
cal_blk_clk => i_tx_calibration_clk,
cal_blk_powerdown => '0',
pll_inclk => i_tx_ref_clk,
pll_powerdown => '0',
tx_digitalreset => '0',
tx_datain => x"AAAAAAAAAAAAAAAA",
coreclkout(0) => memory_clk,
tx_clkout => open,
tx_dataout => tx_dataout_sig
Now I try to connect to the transceiver via the transceiver toolkit. I load the design and clicked on "Link Instance to device ...." but nothing happened. No Transmitter Channel is displayed.
