17255 Discussions
Transceiver Pin Assignment for Stratix 4 GX
Hi
i implemented a transceiver with the ALTGX megafunction and want to assign the pins (tx_dataout_sig[1...4]).
The I/O Standard should be 1.4V PCML. (As seen in the assignments)
set_location_assignment IOBANK_QL1 -to tx_dataout_sig -disable set_instance_assignment -name IO_STANDARD "1.4-V PCML" -to tx_dataout_sig -disable set_location_assignment PIN_AD36 -to tx_dataout_sig set_location_assignment PIN_AD37 -to "tx_dataout_sig(n)" set_location_assignment PIN_AB36 -to tx_dataout_sig set_location_assignment PIN_AB37 -to "tx_dataout_sig(n)" set_location_assignment PIN_T36 -to tx_dataout_sig set_location_assignment PIN_T37 -to "tx_dataout_sig(n)" set_location_assignment PIN_P36 -to tx_dataout_sig set_location_assignment PIN_P37 -to "tx_dataout_sig(n)" set_instance_assignment -name BOARD_MODEL_TERMINATION_V "HALF VCCIO" -to tx_dataout_sig set_instance_assignment -name IO_STANDARD "1.4-V PCML" -to tx_dataout_sig set_instance_assignment -name IO_STANDARD "1.4-V PCML" -to "tx_dataout_sig(n)" set_instance_assignment -name IO_STANDARD "1.4-V PCML" -to tx_dataout_sig set_instance_assignment -name IO_STANDARD "1.4-V PCML" -to "tx_dataout_sig(n)" set_instance_assignment -name IO_STANDARD "1.4-V PCML" -to tx_dataout_sig set_instance_assignment -name IO_STANDARD "1.4-V PCML" -to "tx_dataout_sig(n)" set_instance_assignment -name IO_STANDARD "1.4-V PCML" -to tx_dataout_sig set_instance_assignment -name IO_STANDARD "1.4-V PCML" -to "tx_dataout_sig(n)" set_instance_assignment -name BOARD_MODEL_TERMINATION_V "HALF VCCIO" -to tx_dataout_sig set_instance_assignment -name CKN_CK_PAIR ON -from tx_dataout_sig -to "tx_dataout_sig(n)" set_instance_assignment -name CKN_CK_PAIR ON -from tx_dataout_sig -to "tx_dataout_sig(n)" set_instance_assignment -name CKN_CK_PAIR ON -from tx_dataout_sig -to "tx_dataout_sig(n)" set_instance_assignment -name CKN_CK_PAIR ON -from tx_dataout_sig -to "tx_dataout_sig(n)" But the signal displayed on my scope is only from 84mV to 212mV... So it's nothing about 1.4V PCML.
Do I have to set any other settings?
Thanks for your help!
Thomas
Hi, i'm the colleague of thomas and i wrote the firmeware.
Here are some additional information about the transceiver configuration.
  • Protocol: Basic X4
  • Transmitter only
  • Effective datarate : 1720 Mbps
  • inclk frequency : 430 MHz
  • PLL bandwith: Auto
  • VCCHTX: Auto
  • Pre-emphasis pre-tap: 0
  • Pre-emphasis first Post-tap: 0
  • Pre-emphasis second post-tap: 0
  • Self test mode: none
  • low latency PCS mode is enabled
  • No reconfiguration and loopbacks
We use the Stratix IV signal integrity development board DK-SI-4SGX230N.
I only want to put out a pulscode of '1010...'. The calibration clock signal is the 100 MHz clock from the development board (PIN_A34, LVDS).
i_tx_ref_clk is connected to the transceiver clock PIN_AN38 (LVDS) and generated by a Rohde&Schwarz SMHU Signal Generator ( 430MHz, sine wave)
u_tx_channel : tx_channel port map ( -- inputs cal_blk_clk => i_tx_calibration_clk, cal_blk_powerdown => '0', pll_inclk => i_tx_ref_clk, pll_powerdown => '0', tx_digitalreset => '0', tx_datain => x"AAAAAAAAAAAAAAAA", coreclkout(0) => memory_clk, tx_clkout => open, tx_dataout => tx_dataout_sig ); Now I try to connect to the transceiver via the transceiver toolkit. I load the design and clicked on "Link Instance to device ...." but nothing happened. No Transmitter Channel is displayed.
