17255 Discussions
The setting for TH requirement
i am sorry to trouble you ,but i have a quartus when i use the quartus10 and the timing analyzer is classsis timing analyzer .
first : when i click the assignment -> setting -> classic timing analyzer setting , then in the interface, i find the "th " , then i set the "th" 1ns ,it is ok, but i set it ''1.5ns" ,it show 15ns ,
then i use the .qsf ,and i use the TCL language which is "use set_global_assignment -name TH_REQUIREMENT "1.5 ns" " , and in the " assignment setting " ,the TH_REQUIMENT show 1.5ns ?
then my quartus is why i cannot set the th "1.5ns" in the" assignment -> setting -> classic timing analyzer setting ,th" but i can set it in .qsf .
can you tell me which setting is write ?
thank you very much
dear
I suggest you switch to TimeQuest, which is the recommended design flow. Classic Timing Analyzer is obsolete, maybe not supported well in Quartus any more, as far as I know.
thank you very much , if i use the timequest ,then i must learn it ,but i have no time to learn now , i think i will be learn it next month .
