17258 Discussions
manual placement of components
hello everyone,
how can i implement manual placement of cells in Quartus9.0 web pack?
like creating location constraints for some cells.
thank you,
randeel.
They can be entered in the Assignment Editor or as tcl commands.
hi,
any reference document that describes this task?
thank you,
randeel.
These procedures are basically discussed in quartus ii handbook version 9.0 volume 2: design implementation and optimization, particularly section iii. area, timing and power optimization.
LogicLock regions is another option:
Best Practices for Incremental Compilation Partitions and Floorplan Assignments
http://www.altera.com/literature/hb/qts/qts_qii51017.pdf
found it,
set_location_assignment FF_X16_Y1_N31 -to "component_name"
it is written to the qsf file.
type of thing can be done
http://www.altera.com/education/training/courses/odsw1155
describes how to use chip planner to do Assignments
thank you,
randeel.
Is there a chance to synthesize a script which generates placement contraints automatically from given demands?
I have the task to create a certain structure which has to be organized in a kind a matrix in order to obtain the most possible clean routing delay characteristics between modules.:rolleyes:
--- Quote Start ---
--- Quote End ---
Hi fpgaengineerfrankfurt,
HAve you found a way which generates placement contraints automatically from given demands? I have the same issue. I need to fix the placement of modules in fpga
