17257 Discussions
Pulse Signal using VHDL
Hi. I am beginner of vhdl. Recently, my lecturer gave me new assignment. I want to generate pulse signal with frequency 40kHz using vhdl code. But, i dont know where i should start. I have refer to certain book. But, i am little bit confuse. Could everybody help me to give ideas how can i start :cry:
What are you confused with? what code have you written so far?
Are you a VERY beginner in VHDL ?
I think your lecturer want you to produce synthesizable VHDL code ?
I suppose you already have (your lecturer gave you) an entity declaration and you have a clock (50 MHz, ...)
If you know how will you make that with a few simple logical components, you just have to describe it in VHdL.
Sorry to not help you more ;-)
As Tricky said, post here your piece of VHDL code. If it is just a problem of USE IEEE declaration, or (subtle ;-)) VHDL syntax, sure we help you.
@Tricky: thanks for your suggestion.
@mmTsuchi: Yes. I am very beginner in VHDL. No. My lecturer did not gave me me anything.
Could you suggest to me a book that I can refer since i am beginner in VHDL :(
Hi, Doulos.com gives good examples
For you, http://atlas.physics.arizona.edu/~kjohns/downloads/vhdl/599_2008_94_2797.pdf is quite good (easy to read, examples, simlpe, synthetizable, with good practice).
You seem good to C programming (Nios, software...)
KEEP in mind that VHDL is a description language, NOT a program language (This is a common error for beginners)
Do you have an idea of how would you make your pulse generator with very few components ? (very short schema)
