Hi Ive got a error in my project which is not letting me compile my design...it is giving me 2 errors of node: missing source
Error: Node "inst5" is missing source Error: Node "inst7" is missing source I dont know how to upload my schematic block file...help me... Any help will be much appreciated,,,,P.S. i cant update the software version as I am working of a uni PCLink Copied
--- Quote Start --- Hi Ive got a error in my project which is not letting me compile my design...it is giving me 2 errors of node: missing source Error: Node "inst5" is missing source Error: Node "inst7" is missing source I dont know how to upload my schematic block file...help me... Any help will be much appreciated,,,,P.S. i cant update the software version as I am working of a uni PC --- Quote End --- Hi, it means that "inst5" and "inst7" have undriven inputs. Check carefully your schematic ! Kind regards GPK
Hi I have check the schematic over and over for undriven inputs....but its fine.....plzz helpp...wat shall i do!
--- Quote Start --- Hi I have check the schematic over and over for undriven inputs....but its fine.....plzz helpp...wat shall i do! --- Quote End --- Hi, can you please post your schematic ? If not, try followiing: save a copy of your schematic ( just in case ...) Select inst5 and move it. Are all ports connected to something ? Kind regards GPK
thank you very much...it worked...fank u lots for ur help...much appreciated
