17254 Discussions
Qartus VHDL library problem
Hello to all.
I must compile a little vhdl file (generated with precision rtl).
Quartus gives an error :
Error (10481): VHDL Use Clause error at top_level.vhd(15): design library "cycloneiii" does not contain primary unit "cycloneiii_components"
Can you help me?
-- Definition of top_level
-- 04/01/15 14:54:55
-- Precision RTL Plus , 2013b.15
library IEEE;library altera_mf;library lpm;library altera;
use IEEE.STD_LOGIC_1164.ALL;
use altera_mf.altera_mf_components.all, lpm.lpm_components.all, altera.altera_primitives_components.all;
-- Library use clause for technology cells
library cycloneiii ;
use cycloneiii.cycloneiii_components.all;
entity top_level is
port (
clk : IN std_logic ;
DATA_OUT1 : OUT std_logic ;
DATA_OUT2 : OUT std_logic_vector (7 DOWNTO 0)) ;
end top_level ;
architecture arc1 of top_level is
signal DATA_OUT2_dup_0: std_logic_vector (7 DOWNTO 0) ;
signal inc_d_0, nx27063z1, inc_d_1, nx39256z1, inc_d_2, nx57428z1,
inc_d_3, nx23040z1, inc_d_4, nx58827z1, inc_d_5, nx37857z1, inc_d_6,
nx53431z2, inc_d_7, clk_int, GND_EXMPLR, nx272, nx_top_level_vcc_net:
std_logic ;
begin
GND_EXMPLR <= '0';
ix54494z55375 : cycloneiii_io_obuf port map ( o=>DATA_OUT1, i=>GND_EXMPLR,
oe=>GND_EXMPLR);
clk_ibuf : cycloneiii_io_ibuf port map ( o=>clk_int, i=>clk);
DATA_OUT2_obuf_7 : cycloneiii_io_obuf port map ( o=>DATA_OUT2(7), i=>
DATA_OUT2_dup_0(7));
DATA_OUT2_obuf_6 : cycloneiii_io_obuf port map ( o=>DATA_OUT2(6), i=>
DATA_OUT2_dup_0(6));
DATA_OUT2_obuf_5 : cycloneiii_io_obuf port map ( o=>DATA_OUT2(5), i=>
DATA_OUT2_dup_0(5));
DATA_OUT2_obuf_4 : cycloneiii_io_obuf port map ( o=>DATA_OUT2(4), i=>
DATA_OUT2_dup_0(4));
DATA_OUT2_obuf_3 : cycloneiii_io_obuf port map ( o=>DATA_OUT2(3), i=>
DATA_OUT2_dup_0(3));
DATA_OUT2_obuf_2 : cycloneiii_io_obuf port map ( o=>DATA_OUT2(2), i=>
DATA_OUT2_dup_0(2));
DATA_OUT2_obuf_1 : cycloneiii_io_obuf port map ( o=>DATA_OUT2(1), i=>
DATA_OUT2_dup_0(1));
DATA_OUT2_obuf_0 : cycloneiii_io_obuf port map ( o=>DATA_OUT2(0), i=>
DATA_OUT2_dup_0(0));
nx272 <= '1';
reg_q_7 : dffeas port map ( q=>DATA_OUT2_dup_0(7), d=>inc_d_7, clk=>
clk_int, clrn=>nx272, prn=>nx272);
reg_q_6 : dffeas port map ( q=>DATA_OUT2_dup_0(6), d=>inc_d_6, clk=>
reg_q_5 : dffeas port map ( q=>DATA_OUT2_dup_0(5), d=>inc_d_5, clk=>
reg_q_4 : dffeas port map ( q=>DATA_OUT2_dup_0(4), d=>inc_d_4, clk=>
reg_q_3 : dffeas port map ( q=>DATA_OUT2_dup_0(3), d=>inc_d_3, clk=>
reg_q_2 : dffeas port map ( q=>DATA_OUT2_dup_0(2), d=>inc_d_2, clk=>
reg_q_1 : dffeas port map ( q=>DATA_OUT2_dup_0(1), d=>inc_d_1, clk=>
reg_q_0 : dffeas port map ( q=>DATA_OUT2_dup_0(0), d=>inc_d_0, clk=>
ix2_fadd : cycloneiii_lcell_comb
generic map (lut_mask => X"55aa")
port map ( combout=>inc_d_0, cout=>nx27063z1, dataa=>
DATA_OUT2_dup_0(0), datad=>nx_top_level_vcc_net);
nx_top_level_vcc_net <= '1';
ix6_fadd : cycloneiii_lcell_comb
generic map (lut_mask => X"5aa0",
sum_lutc_input => "cin")
port map ( combout=>inc_d_1, cout=>nx39256z1, dataa=>
DATA_OUT2_dup_0(1), datad=>nx_top_level_vcc_net, cin=>nx27063z1);
ix10_fadd : cycloneiii_lcell_comb
port map ( combout=>inc_d_2, cout=>nx57428z1, dataa=>
DATA_OUT2_dup_0(2), datad=>nx_top_level_vcc_net, cin=>nx39256z1);
ix14_fadd : cycloneiii_lcell_comb
port map ( combout=>inc_d_3, cout=>nx23040z1, dataa=>
DATA_OUT2_dup_0(3), datad=>nx_top_level_vcc_net, cin=>nx57428z1);
ix18_fadd : cycloneiii_lcell_comb
port map ( combout=>inc_d_4, cout=>nx58827z1, dataa=>
DATA_OUT2_dup_0(4), datad=>nx_top_level_vcc_net, cin=>nx23040z1);
ix22_fadd : cycloneiii_lcell_comb
port map ( combout=>inc_d_5, cout=>nx37857z1, dataa=>
DATA_OUT2_dup_0(5), datad=>nx_top_level_vcc_net, cin=>nx58827z1);
ix26_fadd : cycloneiii_lcell_comb
port map ( combout=>inc_d_6, cout=>nx53431z2, dataa=>
DATA_OUT2_dup_0(6), datad=>nx_top_level_vcc_net, cin=>nx37857z1);
ix28_fadd : cycloneiii_lcell_comb
generic map (lut_mask => X"5a5a",
port map ( combout=>inc_d_7, dataa=>DATA_OUT2_dup_0(7), datad=>
nx_top_level_vcc_net, cin=>nx53431z2);
end arc1 ;
Did you install the cycloneiii installation files>?
Yes I did.
But if I change the library name from: library cycloneiii ; use cycloneiii.cycloneiii_components.all;
to: library cycloneiii_components ;use cycloneiii_components.all;
Quartus gives another error: "Error (10482): VHDL error at top_level.vhd(47): object "cycloneiii_lcell_comb" is used but not declared"
If I add the declaration in the architecture of top_level:
component cycloneiii_lcell_comb
generic (
lut_mask : std_logic_vector(15 downto 0) := (OTHERS => '1');
sum_lutc_input : string := "datac";
lpm_type : string := "cycloneiii_lcell_comb"
port (
dataa : in std_logic := '1';
datab : in std_logic := '1';
datac : in std_logic := '1';
datad : in std_logic := '1';
cin : in std_logic := '0';
combout : out std_logic;
cout : out std_logic
end component;
the compilation was successful.
Any ideas??
the library will be cycloneiii or some other similar name. The _componenets is the package name.
Copying the component directly in your code will remove the need for the _components package - but you wont be able to simulate it unless you have a library that maps the componenet to an entity
But then what are the correct libraries to be included for cycloneIII?
try:
library wysiwyg;
use wysiwyg.cycloneiii_components.all;
GOOD!!
it work!!
thank-you!!
