17268 Discussions
Qsys not generating same files in Simulation folder for VHDL vs Verilog?
So I have wondered what is going on here and it seems there is a bug in the program. I am using Altera Quartus II 15.0 64 bit.
I select SRAM/SSRAM controller from the IP catalog. Then I click generate HDL and select Verilog for the "simulation" tab. Now I repeat the same process but select VHDL instead of verilog.
I notice that when I select VHDL I do not get a folder called "submodules" in the simulation folder. However, when I select Verilog, I do. The submodules folder is created and it contains a .v file containing source code for the SRAM/SSRAM controller. Why are different files being generated in the two cases? :confused:
This seems to be a bug in the program. :mad:
It looks like these are maybe components which are only generated in Verilog output. So when you say "VHDL" it is still generating Verilog output for these components. At least when I try, specifying VHDL, Qsys does generate .v file for the controller, same as if Verilog had been requested.
It may not be a bug, it may be deliberate that only Verilog language is supported for generating the file.
(duplicate)
when I select VHDL a folder named submodels is not creating in the folder named simulation which means that I cannot carry out simulation. Atleast it should give me a warning message for this but it does not. For 2 full days I was confused what is going on since I am new to Qsys as well.
This works fine here. If I create an empty Qsys with the SDRAM controller, select language "VHDL" and Generate the system, I am left with foo/simulation/submodules and foo/synthesis/submodules/ directories, both of which have identical copies of the Verilog instance of the controller.
I also have foo/simulation/foo.vhd with the top level.
Are you confusing the "foo/simulation" subdirectory with the top-level "simulation" directory? Qsys puts everything in a new subdirectory of the same name as your Qsys file. The "simulation" folder in your Quartus project directory is for e.g. the gate level / timing accurate simulation models generated as an output of the Quartus compilation.
