17255 Discussions
Quartus 17.1.0 crashed
I have seen this error when I open a project. Can you guys let me know where I can ask this problem?
Problem Details
Error:
Internal Error: Sub-system: THR, File: /quartus/ccl/thr/thr_interprocess_mutex.cpp, Line: 122
err == EACCES || err == EAGAIN
Stack Trace:
0x5db7: thr_internal_error + 0x1e (ccl_thr)
0x9d09: thr_ip_mutex_lock_helper(THR_IP_MUTEX_STRUCT*, bool) + 0x81 (ccl_thr)
0x9d5c: thr_ip_mutex_lock + 0xe (ccl_thr)
0xa4f5: thr_ip_rw_sem_write_try_lock + 0x49 (ccl_thr)
0x11fa4: PROJ_PROJECT::PROJ_PROJECT(std::string const&, std::string const&, bool, std::string const&) + 0x5ea (sys_proj)
0x127a3: PROJ_PROJECT::open(std::string const&, std::string const&, bool, std::string const&) + 0x367 (sys_proj)
0x131ff: proj_dyn_impl_open_project + 0xc (sys_proj)
0xbe192: QUI_PRJ_UI_MGR::open_project(std::string const&, std::string const&, std::string const&) + 0x810 (sys_qui)
0xbc4fb: QUI_PRJ_UI_MGR::open_project_action() + 0xabb (sys_qui)
0xa80e: SSCQ_JS_BRIDGE::open_project_action() + 0x40 (sys_sscq)
0xad3b: SSCQ_JS_BRIDGE::qt_static_metacall(QObject*, QMetaObject::Call, int, void**) + 0xbf (sys_sscq)
0xaffa: SSCQ_JS_BRIDGE::qt_metacall(QMetaObject::Call, int, void**) + 0x5a (sys_sscq)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: linux64
OS name: Ubuntu 16.04
OS version: 16
Quartus Prime Information
Address bits: 64
Version: 17.1.0
Build: 240
Edition: Pro Edition
Are you trying to open project which is created in a different version of Quartus(example if the project is created in sdt version and trying to open in pro version)?
Try to open the project with an appropriate auto upgrade.(if all the IP are supported in the Quartus version, Project will be opened without and any error)
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
Thank you for your comment. Actually, I used the same Quartus tool (version 17.1.0) but generated bitfile in a different OS.
1) Generated a project file and a rbf file on Linux 3.0.101-84-default SMP
2) Opened the project generated in 1) on Linux 4.4.0-116-generic Ubuntu SMP and got the error message.
When I opened the project file in Quartus on Windows 8 it was fine.
I will try to generate the project file on the Ubuntu machine and look at if it has the same issue.
Yoon
--- Quote Start ---
Anand Raj Shankar
--- Quote End ---
