- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
can you please help me out..
My USB Blaster is not shown in programmer window I'm using Quartus 7.2 DE2 kit OS : windows-7 32 bit.. I installed the driver from drivers/usb-blaster of quartus folder whenever i plugin usb, device manager shows as Altera USB Blaster, and when I UPDATE Driver software it says device is up to date !!!! everything looks fine... but my programmer does not recognize usb blaster... I tried every single options running programmer in windows 7 compatability mode.... ....installing even 13.1 quartus...but no luck... Thank you.링크가 복사됨
11 응답
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
quartus 7, is it release in 2007? the win7 first heard release on some thing in 2009... But when you reinstall the 13.1 did you completely uninstall the old 7.2 include delete the folders?
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I believe the QII 7.2 does not support Win7 OS. You can double check on the QII 7.2 release note on the supported OS or check Altera web on this.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
--- Quote Start --- I believe the QII 7.2 does not support Win7 OS. You can double check on the QII 7.2 release note on the supported OS or check Altera web on this. --- Quote End --- yes.. it does not support. but again problem arises with Q13.1 also.. it pops up window saying "device support not installed" in same win7-32bit. even if everything is properly connected. please help.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
yes.. I've uninstalled everything of Q7.2. then for 13.1 is saying that "Device support not installed " !!!!
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
this is bad experience. Okay let continue with 13.1
https://www.altera.com/support/support-resources/download/drivers/dri-index.html Can try to get some driver upgrade/reinstall see if this works??- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Cyclone 2 is only supported up to Quartus 13.0sp1
13.1 does not support cyclone 2 http://dl.altera.com/devices/- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
--- Quote Start --- yes.. I've uninstalled everything of Q7.2. then for 13.1 is saying that "Device support not installed " !!!! --- Quote End --- my friend, are you not seeing the USB-blaster or not able to see the cycone II device?
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
--- Quote Start --- my friend, are you not seeing the USB-blaster or not able to see the cycone II device? --- Quote End --- Device support not installed means quartus has no support for the selected project device (cyclone 2) As I said, Cyclone 2 supported ended with 13.0sp1 (it is not supported in 13.1)
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
--- Quote Start --- Device support not installed means quartus has no support for the selected project device (cyclone 2) As I said, Cyclone 2 supported ended with 13.0sp1 (it is not supported in 13.1) --- Quote End --- oh... my bad.. maybe i read wrongly, as the first message from him is "everything looks fine... but my programmer does not recognize usb blaster..." :D
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
--- Quote Start --- oh... my bad.. maybe i read wrongly, as the first message from him is "everything looks fine... but my programmer does not recognize usb blaster..." :D --- Quote End --- Friends.. I don't get out of this problem.... :cry: one of my friend has installed same Q7.2 on win 7-32 bit.. and his programmer is recognizing usb blaster easily, without any settings and support..!!!! This is dangerous for my laptop....:cry: please help me.. as I have cyclone 2 only.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
please do the following: Start -> Devices and Printers. Do you see the USB-Blaster under the Unspecified section?
