I am primarily a software engineer beginning to work on Quartus II for Cyclone II. What kind of version control tools are available for design files? I am familiar with Tortoise SVN. Is there a similar tool? The sources are managed by different developers.Link Copied
Quartus doesn't have built-in source control integration. Use an external tool. Subversion works fine.
http://www.alterawiki.com/wiki/version_control- Mark as New
--- Quote Start --- Quartus doesn't have built-in source control integration. Use an external tool. Subversion works fine. http://www.alterawiki.com/wiki/version_control --- Quote End --- Thank you very much Ted. I am not quite sure if I have to check in the folders "db" and "incremental db". Do you have any suggestions?
--- Quote Start --- Thank you very much Ted. I am not quite sure if I have to check in the folders "db" and "incremental db". Do you have any suggestions? --- Quote End --- The files in them are used by Quartus to speed up compilation, as they are pre-compiled versions of pieces of your design. If you don't change pieces of the design, Quartus won't repeat the compilation process of those elements and use the files in there. I don't personally check those folders into my repository and just keep them in my local working copy. I try and keep my repo clean of most of the Quartus-generated files, otherwise the repo gets very large and slow. However, my situation is possibly unique since I am the only developer and I am the only one compiling. YMMV. Also, sometimes I find if I get weird compilation errors (errors not relating to changes I've made, or to IP internals) I just delete those folders and do a "fresh" compile. Worked every time so far. Hope that helps. -Dan EDIT: for what it's worth I am using Git/Tortoise Git to manage my version control
