17254 Discussions
Quartus quit unexpectedly
DNguy4
I am using Quartus 18.0.1 and it quit unexpectedly several times today during synthesis and analysis step with the following error message. Any idea how to deal with this?
Problem Details
Error:
*** Fatal Error: Access Violation at 00007FF95F2F9CA8
Module: quartus_syn.exe
Stack Trace:
   0x39ca7: HDB_DESIGN_UNIT::get_library + 0x2b (DB_HDB)
   0x36512: QIS_RTL_STAGE::IMPL::process_pre_compiled_partition + 0x302 (synth_qis)
   0x32310: QIS_RTL_STAGE::IMPL::elaborate + 0x1a0 (synth_qis)
   0x4e1cf: QIS_RTL_RECURSIVE_ELABORATION::after_elaboration + 0x7f (synth_qis)
   0x339e0: QIS_RTL_STAGE::IMPL::elaborate + 0x1870 (synth_qis)
   0x16a68: qis_elaborate + 0x168 (synth_qis)
   0x16442: TclNRRunCallbacks + 0x62 (tcl86)
   0x17c4d: TclEvalEx + 0x9ed (tcl86)
   0xa6a8b: Tcl_FSEvalFileEx + 0x22b (tcl86)
   0xa5136: Tcl_EvalFile + 0x36 (tcl86)
   0x13ab0: qexe_evaluate_tcl_script + 0x340 (comp_qexe)
   0x12c8f: qexe_do_tcl + 0x33f (comp_qexe)
   0x182ce: qexe_run_tcl_option + 0x5ee (comp_qexe)
   0x243c3: qcu_run_tcl_option + 0xd43 (comp_qcu)
    0x11d9: qsyn2_tcl_process_default_flow_option + 0xa9 (quartus_syn)
   0x17bca: qexe_run + 0x3aa (comp_qexe)
   0x18c63: qexe_standard_main + 0xb3 (comp_qexe)
    0x40c9: qsyn2_main + 0x129 (quartus_syn)
   0x13c58: msg_main_thread + 0x18 (CCL_MSG)
   0x14f6e: msg_thread_wrapper + 0x6e (CCL_MSG)
   0x1e920: mem_thread_wrapper + 0x70 (ccl_mem)
   0x13041: msg_exe_main + 0xa1 (CCL_MSG)
    0x5764: __scrt_common_main_seh + 0x11c (quartus_syn)
    0x8363: BaseThreadInitThunk + 0x13 (KERNEL32)
   0x6e820: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Executable: quartus_syn
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 18.0.1
Build: 261
Edition: Pro Edition
Tricky
New Contributor II
If you have deleted the db and incremental_db folders, and it keeps happening, you may need to raise a support ticket.
DNguy4
Thanks Tricky. deleting qdb helps but any idea why it helps? Some files in there are corrupted?
Tricky
New Contributor II
No idea. But it's been an answer for a long time
