17252 Discussions
Quartus II Web Edition not communicating with USB-Blaster on OpenSuSe 12.1
I have succesfully installed Quartus II Web Edition 12.0sp2 on OpenSuSe KDE4 12.1 x86_64.
Quartus II is working in 32 bit operation. (not configured as 64bit during installation)
I have an sample project succesfully compiled without any errors on Quartus II.
But when i try to programm the .sof file to my EP3C25 Starterboard, the programmer doesn't show the USB-Blaster in the programmer configure window.
If I start de command "hwinfo --usb" by terminal in su mode I get the following output info;
14: USB 00.0: 0000 Unclassified device
[Created at usb.122]
Unique ID: ZmS7.7UPKMDz+LLB
Parent ID: 7eqy.v+N+B0xY+P6
SysFS ID: /devices/pci0000:00/0000:00:1d.0/usb6/6-1/6-1:1.0
SysFS BusID: 6-1:1.0
Hardware Class: unknown
Model: "Altera USB-Blaster"
Hotplug: USB
Vendor: usb 0x09fb "Altera"
Device: usb 0x6001 "USB-Blaster"
Revision: "4.00"
Serial ID: "91d28408"
Speed: 12 Mbps
Module Alias: "usb:v09FBp6001d0400dc00dsc00dp00icFFiscFFipFF"
Config Status: cfg=no, avail=yes, need=no, active=unknown
Attached to:# 8 (Hub)
So far conclusion SuSe is detecting the USB-Blaster
But when I start the command "jtagconfig" I get the following message;
hkopp64@linux-y0kk:~/altera/12.0sp2/quartus/bin> jtagconfig
*** The Quartus II software cannot be started because the current platform,
'linux64', does not appear to be installed in:
'/home/hkopp64/altera/12.0sp2/quartus'.
Error (Server error) when scanning hardware
Quartus II jtag programmer is pointing to a 64bit dir, but how can I correct this to get the programmer working with the USB-Blaster into 32 bit operation ?
Kind Regards
Huib
:confused:
I have found an solution but the problem starts by installing of Quartus II that the linux64 directory will not uncompressed and saved under altera/12.0sp2/quartus directory
My solution is to manually gzip the linux64.gz file and save under altera/12.0sp2/quartus.
Now start jtagconf by terminal and the USB-Blaster shows up !
Problem solved :)
