I am using Quartus II 9.1 and I archive the results of a run. Then I unarchive the QAR and re-run the flow without any changes to settings. But now the results dont perfectly match with the original run. Is this expected? While archiving, I use the default option (not archiving reports, prog. files). Regards, SatishLink Copied
What kind of mismatch do you observe?
--- Quote Start --- What kind of mismatch do you observe? --- Quote End --- I see mismatch in timings. New violations appear and some disappear.
Topic Options
